Ingalls Clutch Line
This is interesting. I've been looking for a way to get a more reliable clutch disengagement point. It seems depending on ambient temp, Engine rpm, and shift speed that the engagement and disengagement point in the Clutch pedal travel arc changes. Its quite annoying especially when trying to shift quickly.
Does the clutch and brake use the same fluid reservoir or are they seperate? I have a clutch line ready to install but I want to make sure I am adding fluid to the correct reservoir when I bleed it.
Originally Posted by ColonelSanders85
What website did you order the Ingalls clutch line off of?
http://www.dezod.com/pd-dezod-motorsports-stainless.cfm
Been running this for a long time maybe two years. The line offers increased clutch feel. The line won't expand as much as the OEM line when there is pressure on it (It not expanding a lot just a little, but with Ingalls line its very little, and harder clutch pedal). I am using Motul Dot 4 and I also bought a longer push rod for the clutch slave cylinder because of the aftermarket clutch.
