Installed Ingalls Torque Damper
Old May 8, 2006 | 01:41 AM
coppermine18's Avatar
Default Installed Ingalls Torque Damper
I LOVE the feeling. The motor isn't flopping around anymore.
The pedal is down to business now, when the car takes off there is a slight vibration because the motor wants to just rock back and take a lil power that it should be immediately applying wheels when you want it. The damper is hard at work preventing this.
Shifting is smoother as each gear is ready to roll, soon as the clutch comes out the power is there with no lag from the motor rocking around.
If you just let on and off the pedal you can tell what a difference it really makes, which for me is awesome in AutoX - reaction times and putting the power down comming out of corners is critical.
Anyways - I think for anyone serious in putting there mods to good use and keeping the power down - GET ONE. I am impressed.
http://www.ingallseng.com
Some pics of the damper. Any questions, I'd be glad to answer.
Old May 8, 2006 | 01:43 AM
exige's Avatar
does this thing improve autos or only 5 speed's
Old May 8, 2006 | 02:37 AM
Neothin's Avatar
it will help sticks shift better, but not having the engine going all over the place will help both transmissions. reason being, wheel hop is controlled.
Old May 8, 2006 | 03:57 AM
DTRUONG_112's Avatar
nice man. How does it feel when you launch it from a dig?
Old May 8, 2006 | 05:12 AM
I haven't launched hard yet, I will this weekend and maybe get some video for you guys.
I do know launching from a roll feels great.
Old May 8, 2006 | 05:13 AM
Kilo6_one's Avatar
its adjustable right? what setting do you have it on?
Old May 8, 2006 | 05:21 AM
XD40tC's Avatar
Its adjustable but hard without the exact tool needed which I couldnt seem to find anywhere. So mine ended up with a few scratches... worked great though on my auto and I'll get another soon enough!
Old May 8, 2006 | 05:23 AM
Kilo6_one's Avatar
your going to run two? how is the vibration?
Old May 8, 2006 | 05:24 AM
zer0's Avatar
Its useless unless you put it on the max stiffness. I still had wheel hop with the stock setting.
Old May 8, 2006 | 05:43 AM
I set mine to 11mm to is the stiffest 14mm is the softest 10mm is the stiffest.
I didn't want it soft.
You do get some cabin noise (which I like) but I think that a lil piece of dynamat or phat mat on the shock tower can reduce the sound if for some reason it bothers you.
I will be putting some on and I will let you know how it sounds afterwards.
Old May 8, 2006 | 06:19 AM
BigPinoyTC's Avatar
Well since i got my Turbo i have been having A LOT of wheel hop and motor movement. For the past few days i have been thinking if i should make this purchase.
Well because if your post and others i just made my purchase and can't wait to get it in.
Old May 8, 2006 | 06:24 AM
Sweet - yeah def with a turbo. I was gonna turbo till I started AutoX'n now I'm gonna supercharge cause I just need the low end.
Take pics for me!
Old May 8, 2006 | 04:45 PM
grmorrow04's Avatar
Does this get in the way of the DC strut bar at all? Any modifications necessary due to the strut bar?
Old May 8, 2006 | 04:54 PM
Nope fit perfect... I had no problems - I just mounted the strut bar on top of it.
Here is a pic:
Old May 8, 2006 | 08:39 PM
sONicRoK1's Avatar
i was thinking about getting this...
now that i know what it is i guess it would be a good investment.
Old May 8, 2006 | 08:52 PM
hunterUnknown's Avatar
whether or not its feasible, i kind of wish they did both sides of the engine. but its good to hear it works!
Old May 8, 2006 | 09:19 PM
DynomyteSW's Avatar
I put washers under the driver side of the strut bar to make sure the strut bar was level... make sure the washers are as thick as the damper bracket though.
Old May 8, 2006 | 09:22 PM
DynomyteSW's Avatar
if one damper isnt enough then you should get some stiff motor mounts... or solid mounts that would sure cure any motor movement you have lol
Old May 8, 2006 | 09:58 PM
stl_tc_king's Avatar
would the price/ advantage ratio be great enough to justify buying this if I have no engine mods (besides CAI)?
Old May 8, 2006 | 10:41 PM
Well it helps to prevent wheel hop which could lead to more broken parts.
Just say 'no' to wheel hop.
