I've got a quick/cheap/easy way to rememdy CAI vibrations
Old Oct 10, 2007 | 01:16 AM
BurntClutch's Avatar
Default I've got a quick/cheap/easy way to rememdy CAI vibrations
For those of you that are hearing a rattle in the upper part of your front fender after installing a cold air intake here is my quick fix for it. As long as you know your mounting brackets are not broken, your intake is probably rattling on the inner fender where the pipe goes through that little space that is a pain in the ___ to get the pipe to go through.
Now, with my Injen intake they included a 12 inch piece of material that was supposed to fit around the edges of that hole to protect, but i found this to be a piece of crap that didn't fit/work well even after trimming it up.
So, I installed the intake without it, and it rattled and vibrated like crazy when on the throttle or hitting bumps. I went to local auto parts store and bought the smallest possible roll of window seal gasket that they had. The store had rolls that were used for different applications, but the stuff I bought was flat. What it is is this soft foamy/rubbery stuff about an inch wide and one side of it has a sticky backing on it. All I did was cut two small pieces and peeled the rubber backing off, and placed them on the top and bottom parts of the intake pipe that was making contact with the inner fender causing the vibration.
I have not had any more vibration/rattles and it was 60 seconds of my time to put these little pieces of stuff on. The nice thing is you don't have to take apart the intake or anything at all. The only downside I figure is if/when you take the intake off you have those two pieces stuck to it, but I'm sure you could peel them off and remove the residual 'stickiness' with some cleaner if you want to sell your intake.
Thats my quick little fix for the intake vibration. If nothing else you could put them on as a temporary fix so you don't put a hole or dent in your pipe if you've got other plans for your engine. However, it seems like it is an easy permanent fix as well.
I hope it helps someone at some point, and of course if this is going to ruin something or make my car fall to pieces please tell me ASAP so I can fix it the expensive way!
Old Oct 10, 2007 | 01:25 AM
Deviousjet's Avatar
I also found that if you get a beer cooler cut off the bottom and wrap it around the part that rattles voila It's a 99 cent fix and I have the tazmanian Devil!!! LOL
Old Oct 10, 2007 | 02:19 AM
shadow12one's Avatar
Doc I has an intake fender liner thing. forgot what its called. Im sure that keeps your intake from rattling as well as your fender from damaging the cai
Old Oct 10, 2007 | 02:39 AM
DonNguyen's Avatar
here's what he's referring too
http://doctorisotope.com/index.php?o...d=25&Itemid=29
Old Oct 10, 2007 | 03:04 AM
Tcguy85's Avatar
i bought one of those from doc and it didn't fit right.
Old Oct 10, 2007 | 03:06 AM
DonNguyen's Avatar
did you order the right one?
this is the first i've ever heard something wrong with a Doc I product
Old Oct 11, 2007 | 03:16 AM
Sleek98's Avatar
man im going to try this one. I cant believe i didnt even think of this, thanks man
Old Oct 11, 2007 | 03:39 AM
rolloutrs1's Avatar
you can also just use double sided tape on both sides and you wont hear it vibrate/rub to the fender.
Old Oct 11, 2007 | 04:43 AM
Tcguy85's Avatar
yea i ordered one for the injen and it didn't wanna fit right.
Old Oct 11, 2007 | 01:51 PM
powerofSHN's Avatar
Team Hamster
I also have an 07 Injen CAI with the Doc I's panel and they don't fit either. Was just installing it last night and it was not fitting. I have the panel just sitting around the CAI for now until I get a better fix.
Wonder if the the 07 Injen intake (different than the 05-06 model) would require a different design from Doc I. Just a thought.
Old Oct 11, 2007 | 05:44 PM
megrog2's Avatar
I also bought one and it didn't fit right either, after a couple of months the bolts vibrated out and it wouldn't stay in place. I ended up chucking it.
Old Oct 11, 2007 | 08:48 PM
MonkeyBoi's Avatar
I think it would be better to use insulation wrap. keeps air cooler and keeps it from rattling ya? Problem is it'll look crappy.
Old Oct 11, 2007 | 09:22 PM
Sleek98's Avatar
what kinda insulation wrap are you refering to?
Old Oct 11, 2007 | 11:51 PM
straightsilver21's Avatar
same problem with the doc I intake insert for the Injen CAI. it sat too far forward. I had a pain in the rear of a time getting it to the fender from the middle joint in the pipes by the MAF. The only way for me to maneuver it in better would be to move the fuse box,.... or to put it on when i originally installed the CAI making getting that pipe through even more annoying.
Old Mar 14, 2008 | 01:56 AM
CSOCSO's Avatar
i have k&n cai and the arm (bracket?) which holds the pipe is broke again.. i have it welded but now its broken somewhere else... so hurray.. rattle.. rattle.. rattle.. just ordered the fendermount panel from doc... i hope it will be good...
yeah.. and behind that part im gonna heat wrap it all the way to the filter..
Old Mar 14, 2008 | 02:49 AM
krazyqban352's Avatar
The best way to do this is to just get about a foot of vacuum hose at the parts store, cut a straight line down it and wrap it around the innner fender, it is easy and works perfect.
No need for the window sealer or the doc I plate.
Old Mar 19, 2008 | 01:35 AM
CSOCSO's Avatar
i did try a lot of thngs like that.. wrapped around the intake with sponge.. then i used some rubber., etc.. but the cai was moving too much so the bracket is broken again.. plus everything was ripped apart where it was rubbing with something.. so i ordered that dr. isotops fender mount panel.. arrived today.. installed, and its awesome. i had to remove my inner line fender because , i had to take apart my cai but like this it was really easy to install the fender panel.. it moves just a little so i went to a muffler shop to have them re-weld the bracket... but im not sure if its good if the cai cant moe too much now its pretty massive.. i hope it wont brake or crack...
btw there should be bracket above the filter???????????
just above the filter there is a hole for a bolt....... but i have no bracket there... do i missing something?
Old Dec 11, 2009 | 11:53 PM
ldywde's Avatar
my D I insert didnt work either but I still have it installed + a mesh cloth to block all of that rattle noise!
Old Dec 12, 2009 | 03:37 PM
CSOCSO's Avatar
yeah.. i had the DI panel for a while then i took it off because i ordered the lower bracket and actually i couldnt install it with the DI insert.
yupinmytC
22
Jul 27, 2024 07:08 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
mikeac
Sep 15, 2015 03:24 PM
Chrono
Aug 25, 2015 05:59 PM
