little startup issue
Old Sep 1, 2009 | 10:07 PM
my06tc's Avatar
Default little startup issue
ok you gies......if you dont know i have a 06 tc with 48k miles on it..and recently i noticed that when i go to start the car up it sounds like its hesistaing to startup (first time each day) i mean it will start but with a hestitation then with it does it jumps very quickly to 2k rpm which is normal from what i heard then drops down to 1500 rpm then finally down to 800 rpm when all said and done....
its not a smooth start up like it use to be...but im thinking maybe the spark plugs are worn out and having a little issue producing a spark..cause when the car is all warmed up its fine no problems but its only when the car is first starting up...its weird....i step on the clutch i turn the key to on position for 5 secs then turn the ignition on...little hesititaion then finally catches and quicly goes to its procdures almost like it was having a hard time catching a spark....i know its not normal on what im experiencing but just thought i would ask.... please dont bite me
Old Sep 1, 2009 | 10:09 PM
ack154's Avatar
The spark plugs should last nearly 100k, so that might be unlikely.
Does the engine crank and just doesn't fire up? Or do you not even hear it turn over?
Old Sep 1, 2009 | 10:39 PM
rangerryda's Avatar
Do you have any performance mods done?
Old Sep 1, 2009 | 10:51 PM
elcapetan's Avatar
mine does the same thing. I have intake header exhaust. It seems like it isn't firing.
Old Sep 1, 2009 | 10:58 PM
elcapetan's Avatar
My issue may be diff but it turns over for 4-5 sec b4 actually starting up.
Old Sep 1, 2009 | 11:18 PM
IH8ONYU's Avatar
though the spark plugs "should" last nearly 100k, the stock plugs in my xb were shot after 25k.. the gaps had all opened up quite a bit and the electrodes were chipping.
put in some irridums, and i check em often now to be sure there is no oil blow by, fouling etc... no issues now.
Maybe the same problem in the TC, its an easy check that takes only 5 min, just have some anti sieze ready when you reinstall the old or get new plugs.
Also, you may want to check your battery terminals for corrosion, and check to see that your frame ground is making good contact..
Old Sep 2, 2009 | 12:14 AM
my06tc's Avatar
i have injen cai ..megans drift spec exhasut and a downpipe...but i doubt its that il just make the car louder...it crank over it start fine but like elcapetan said takes about 4-5 secs before it actually starts...my buddy has the same car and same mods as me he doesnt have that problem nice and smooth start up....he actually said i should check out the sparks plugs might need to be replaced..its weird how people say things should last for 100k miles i dont think so too long thats if you dont drive the car alot....but im goona check my spark plugs..my battery is fine no corrision
engine cranks..fireups fine..everything starts.. its cranks over then small hasitation then finally the engine starts... its werid to explain but ill do my best
Old Sep 2, 2009 | 12:50 AM
rangerryda's Avatar
Reset the ECU by disconnecting the negative battery terminal for a few minutes. That will reset all fuel trims.
Old Sep 2, 2009 | 12:53 AM
getaforknjob's Avatar
My car does the same exact thing.
Old Sep 2, 2009 | 02:35 AM
elcapetan's Avatar
where exactly is the ground for the frame in our cars?
Old Sep 2, 2009 | 03:25 AM
Steventc07's Avatar
under the battery
Old Sep 2, 2009 | 05:00 AM
rangerryda's Avatar
It's under the tires JK Just follow the main lead off of the terminal to see where else it is grounded. Many cases the ground goes off to 3 or 4 main grounds like the motor/tranny/chassis/firewall/fuse and relay panels etc.
Old Sep 2, 2009 | 11:52 AM
ack154's Avatar
The tC already has iridium Denso plugs. Surely they could be checked... but it's just unlikely.
Old Sep 2, 2009 | 01:00 PM
ecko04's Avatar
4 to 5 sec is a long time for the car to crank. Mine fires right up 07 @ 52k.
djcezile
Apr 23, 2015 06:46 PM
nazblue5807
Apr 11, 2015 12:20 AM
zap-o-matic
Apr 2, 2015 07:35 PM
cid_mcdp
Jan 5, 2015 02:45 PM
EthanAJS
Dec 21, 2014 10:16 PM
