maint. light
alright i already have the oil pressure gauge q, up. But while i was fixing the oil pressure gauge, the leak i was fixing, i started the car, and all the oil spewed out onto the engine. so it took me like 3 hours wiping and and gently hosing it off to get the oil off. well my maint. light came on and i knew i needed oil. so i filled it up with oil and now the maint. light when i start the car blinks for like 30 seconds and then turns off. why is this. thanks
after doing a oil change you have to reset the main light...courtesy of http://home.cfl.rr.com/icdedppl/faq.html
8. how do i clear the 'maintenance required'/oil change light using the trip meter button?
if at the time you changed your oil, you or the person changing your oil did not reset the 'maintanence reqiured'/oil change light or if you would just rather turn it off instead of setting the interval (aka- the lazy way to turn off that annoying light), follow these steps:
step 1 turn the key to the 'on' position.
step 2 reset both trip meters to zero. you can reset the trip meters to zero by selecting trip a or trip b and holding in the trip meter button for five (5) seconds.
step 3 after both trip meters are reset, select any trip meter and hold in the trip meter button and start the car.
step 4 continue holding the trip meter button until the "maintenance required' light disappears.
xBSciontist
Jun 18, 2019 03:06 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
