minor exhaust leak
Old Sep 21, 2006 | 06:22 PM
3min3m2's Avatar
Default minor exhaust leak
ok i had a second resonator installed on my drift spec exhaust to quiet the header(which i no longer have)
instaed of dealing with the local shop(\minor rant\catch crap cause i'm modifying a 4 cylinder....sorry i dont live and die by muscle cars \endrant\)i have decided to *patch* it...i plan on using something simple like a JB weld...this section doesn't get extremely hot(it's about 6 inches past the drift spec's primary resonator, and its a basically under the rear seats. the problem is it was not totally sealed when installed it was just slipped on, and hope for the best...so now whne the car is cold it sounds really raspy, but kind of goes away as it heats up....but as it gets even warmer.(driving through traffic, a good 1hr+) the exhaust gets louer, but not raspy
yeah....really wierd, but this seems like this is the problem, so i think this works
anyone have any other suggestions as in what products to use instead of JB Weld??
its aluminum to stainless steel
Old Sep 21, 2006 | 06:28 PM
web's Avatar
web
If you have a torch, just heat that area up to close to red hot. Aluminum has a lower melting point than steel and when both heat up and touch, they chemically weld themselves together. If you can't do that, try using exhaust puddy instead of JB Weld. Might mend the hole better.
Old Sep 21, 2006 | 06:46 PM
tcengel's Avatar
Mine is the same way and my resonator and cat are welded in. This is basically just the way the drift spec muffler sounds. It sounds best when warmed up, but worse when the car is heatsoaked like when sitting in traffic.
Your best bet is to try a new muffler if the sound bothers you that much.
Old Sep 21, 2006 | 06:50 PM
web's Avatar
web
I'm going Spintech. Throaty sound at WOT and nice grumble at low rpms
Old Sep 22, 2006 | 03:58 PM
3min3m2's Avatar
it didnt sound that way before i had the resonator installed
io dont have access to a torch(at least not easily and safely) but i did find an exhaust putty...i'll be good to go this weekend
thanks anyways
Old Sep 22, 2006 | 04:00 PM
web's Avatar
web
NP
Old Sep 22, 2006 | 04:09 PM
tcengel's Avatar
That's because it was so damn loud you couldn't tell the difference.
Old Sep 22, 2006 | 04:11 PM
3min3m2's Avatar
dude...i can feel the air coming out of the resonator....
i know it's leaking
Old Sep 22, 2006 | 04:15 PM
web's Avatar
web
If you got it welded in, patch up the welds really thick with that exhaust puddy. Or, just take it to get a 10$ weld job done if it's leaking from there. But, that puddy should be enough. Good luck.
Old Sep 22, 2006 | 04:17 PM
3min3m2's Avatar
im just going for the putty...they didnt weld the resonator in, its a sli[p fit to a piece of pipe, weled the pipe to my megan...kind of a crappy job, didn't look at it till it was too late...which was my stupidity..
which is why i wouldn't take it back to them to weld it(there theo nly place around her close that does exhausts)
Old Sep 22, 2006 | 04:18 PM
tcengel's Avatar
If you can feel the air, I doubt puddy will last too long. Just pay the $10 to weld it.
Old Sep 22, 2006 | 04:32 PM
web's Avatar
web
The puddy hardens into a steel-like compound. It doesn't stay soft.
Ferretgrrl
Oct 15, 2018 02:50 AM
RY_TC07
Jul 18, 2017 05:18 PM
xa007xa
Feb 22, 2015 03:05 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
