Mishimoto 2 core aluminum radiator installed and review
Originally Posted by B_Real45
Originally Posted by Ace83
^^ mine is at the shop being installed, we'll see how it goes
lol
Pusher fans usually don't produce as much desired cfms of air as pullers do, but when you're tight on space, you gotta do what you gotta do. Pullers with shrouds can utilize all the air passing through the radiator but pushers can only put the air through a limited area of the radiator.
Pushers are usually best as auxilary fans to be used for extra cooling and track days.
I have a 14" 1900 cfm mishimoto fan that I may install for an auxilary setup for the track, but still debating. It will have to be a pusher but I am not sure if it's going to fit correctly. May have to space it out away from the core support of the radiator but we'll see how it goes.
If interested about it, PM me. Still in box and I have the mounting kit as well
I bet at most you have about 1/2" to 3/4" gap between the turbo housing and the radiator......most likely will have to do a bit of fabricating in the support brackets to push it forward a bit more. Let's see those pics
Originally Posted by My07Tc
Since it is a dual core setup does it hold more fluid?
Yes it's a 2-row and yes it does hold more fluid.
I've got the 14" mishimoto fan that I may add but still am debating b/c it's working more than great right now.
I have the mounting kit as well from mishimoto. I may just sell it so let me know if you need one.
Originally Posted by ippskidder
Niceee, let me know how it goes.
Btw, are those the mishimoto fans? and did you get the adapter kit with it?
