misshifted and redlined at 8000rpms
Old Oct 9, 2006 | 03:20 AM
flintgauge86's Avatar
BTW, you can't get into reverse while you're moving forward. Even if somehow you managed to make it happen, everything (everything) in your drivetrain would literally explode.
Exactly. You would have to have your front seat passenger help you put it into reverse if you were going that fast. The tranny would refuse to do it. It would probably rip your hand off as it kicked it back out.
Old Oct 9, 2006 | 03:26 AM
djrza786's Avatar
I'm not sure if this is getting off topic, sorry if it is, but what is the differance of what he did to when people redline when they are just driving normal, like racing? You hear it all the time, especially in drifting, you can tell the driver is redlining and you can hear the engine sputtering. Is that ok? I've done that once before, just didn't shift in time.
Old Oct 9, 2006 | 03:27 AM
Whocares05050's Avatar
Would a dealer do a compression test under warranty?
and WTF is a leakdown test?
Old Oct 9, 2006 | 03:31 AM
becuz if he went into gear, from 3-2 instead of 4th say, at 65-70 mph, the force of the cars speed would force the engine to rev above the rev limiter, above redline, much higher. This is much worse the tapping the rev limiter.
Old Oct 9, 2006 | 03:32 AM
SquallLHeart's Avatar
well.. when driving/racing normally.. the ecu has a rev limiter that'll cut off the throttle at redline so you don't overrev and blow the engine.. downshifting on the otherhand can override that and have the engine rev over 9K if you want and then the engine will go bye-bye.
and doubt they'll do it under warranty... and esp. if something breaks.. it won't be covered... and they'll know...
it's driver error.
leakdown test is just that.. checking for leaks.
Old Oct 9, 2006 | 04:45 AM
Prototype_xB's Avatar
Originally Posted by eLpReSiDeNtE
once again AUTOMATIC!!!!.....lmao
Old Oct 9, 2006 | 04:46 AM
i still say AUTOMATIC!!!!!lmaoooo....im juss being a pest dont mind me people!
Old Oct 9, 2006 | 05:07 AM
DUDE! Don't hate the third pedal! Ya'll are just jealous! Just becuz some of us can't drive sticks doesn't for one second mean autos are superior...
Old Oct 9, 2006 | 11:29 AM
tCizzler's Avatar
I really don't know how i got it into reverse, not a clue. But i KNOW FOR A FACT I DID. I actually couldn't get it out off reverse after that for a minute. I had to hold in the clutch and coast until i finally punched the shifter outta reverse. And after that all the gears were hard as hell to get into,it was like the synchros all got messed up. But like i said, it took a couple minutes of driving and shifting for it to get better. But as of today everything is good.
Do you think i still need a compression check, my car runs fine, like the day i bought it. And what would show up and/or need replaced if something was wrong? Headgasket? Valve seals?
Old Oct 9, 2006 | 03:57 PM
vvti24's Avatar
im starting to hear some whistling noise when idling at 4rpms.. i deno if its an exhaust leak or what... My friend told me to check for a valve tap.. Wat's a valve tap?
Old Oct 9, 2006 | 05:19 PM
tCizzler's Avatar
just to clear it up, what is idling at 4rpm. Cars idle at 700-800 typically
Old Oct 9, 2006 | 06:49 PM
citizen01's Avatar
When I first got my car I was so excited/inexperienced I took it off the dealer lot and went from 4 to 3 on the freeway a couple miles down the road. The tires chirped but I got the clutch engaged pretty quick after that. Needless to say I hated myself after that.
Old Oct 9, 2006 | 06:58 PM
Old Oct 9, 2006 | 07:11 PM
superscionik's Avatar
8000 RPM? Wow, really? 8000 RPM?
Old Oct 9, 2006 | 07:28 PM
Thats just your airbox doing that. normal
Old Oct 9, 2006 | 07:32 PM
azepolyn's Avatar
^^ I don't think the airbox whistles at idle ... my injen wouldn't even whistle at idle ...
Old Oct 9, 2006 | 07:44 PM
sosgal721's Avatar
could be the idler gear
Old Oct 9, 2006 | 07:57 PM
eLpReSiDeNtE's Avatar
tC squad
Old Oct 9, 2006 | 10:41 PM
sosgal721's Avatar
lol if you are realy idleing at 4(000?) RPM's then well there's your problem.......
Old Oct 10, 2006 | 12:06 AM
vvti24's Avatar
sorry for misinterpreting, when i meant idling at 4k is when im crusing at around 80mph i hear a whistling noise.. i dont know if im being just paranoid but i feel like my car's droning a lot more too...
note i have basic bolt ons, injen cai, trd exhaust, alphawerks header and 2.5 inch magnaflow resonator...
