my slight header delemia
so ig ot my new headers on but i couldent get the gasket of the bottom of my headers on my 07 its like there glued on. so i put it together but i dont know if there is actully a leak or not how would i know if there is?
Originally Posted by george_da_2nd
how do i get tem off tan i even used wd 40 its retarted
NEVER use wd-40, PB BLASTER is the best for getting stuff off
Originally Posted by SoccerBoy_AP
No,
Its a yellow can and its called PB Blaster:
^^^^ x2.
yeah, i don't think toyo/scion properly treated the stock exhaust manifold to withstand the high temps they would encounter.... hence why all the metal is fusing together.
u need/want to have a gasket on there.
its recommended to buy a new one anyway, everytime u remove the exhaust manifold. because the gasket gets compressed and warped over time.
Hey is your TRD exhaust louder with your new header? Cause my car I had a header in there and I just put on the TRD exhaust and it's wicked loud and it rattles. I had the injen exhaust on before but I never took off the silencer.
well before you get a new gasket, let the car cool down then start it up and wrap you hand arond the 2 flanges and see if you can feel a leak. if not then your probably good but check it again after a couple hundred miles. if it does leak, replace it and make sure the 2 pipes come together right.
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
