No Power to Crank and Cam Sensor..
Old Jan 5, 2020 | 07:15 PM
ScionOwner's Avatar
Default No Power to Crank and Cam Sensor..
Hello everyone, I'm at a stand still here have been for 2 weeks. I am in need of some help. This is the second motor I am putting in this car. And I’ve done corollas with the same motor. I’ve never experienced this problem.
I have a 2005 Scion tC got the head shaved put connecting rods head studs and head bolts in. Got the motor trans and just about everything else set in the car and it crank shut won’t start. Checked the injector plugs
they’re getting power also getting 50-70 psi across the board on all injectors. I’m not getting spark but I’m getting power to all the coil packs.
Also not getting power to the crank and cam sensors.
And ideas?
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Jan 5, 2020 at 08:18 PM. Reason: Moved to Correct Forum by Administrator
Old Jan 5, 2020 | 08:25 PM
62Fender's Avatar
This may sound like a dumb suggestion but I'd hook up a DTS scanner to see if anything was overlooked.
Old Jun 8, 2020 | 02:57 AM
ScionOwner's Avatar
Found a solution, had to get the computer reprogrammed. Something about the immobilizer and the key. Built the motor and going to get a turbo for the thing!!
TimsScion07
13
Jul 14, 2019 03:26 AM
rican_lunatic
Sep 10, 2012 05:34 PM
3min3m2
12
Mar 5, 2008 01:37 AM
TurboToyotas
23
Jul 2, 2007 12:40 AM
fredrick_brown
16
Jun 3, 2005 09:55 AM
