noisy motor
Old Apr 5, 2007 | 06:11 AM
DANIEL209's Avatar
Default noisy motor
are all tc motors noisy at idle?i've owned several acura's and civics but never had a motor this noisy.it almost sounds like the valves need adjustment.anyone have the same problem?
Old Apr 5, 2007 | 06:13 AM
Neothin's Avatar
nope, normal.
Old Apr 5, 2007 | 06:17 AM
SquallLHeart's Avatar
noisy? engines normally make sounds when they're running.
Old Apr 5, 2007 | 06:18 AM
Neothin's Avatar
but i too have noticed that the tC is more clanky than others..
Old Apr 5, 2007 | 06:23 AM
DANIEL209's Avatar
i know motors usually make noise when their running, you genius.
thanks for the info.
Old Apr 5, 2007 | 06:26 AM
besides the clankiness that neothin mentioned.... perhaps you can elaborate a little more as to what "noises" you are hearing?
is it at intial startup? or is it happening even after it's warm?
Old Apr 5, 2007 | 06:37 AM
DANIEL209's Avatar
well i had a supercharged integra and sometimes it had the same ticking except i knew it was the valves.i purchased this 2006 tc brand new and as i was pulling my car into the garage i noticed it had the same ticking from the block i assume. but after giving it some thought it might be because these motors run off timing chains and not rubber belts.
Old Apr 5, 2007 | 06:46 AM
could be the case. no rubber belts for this motor. (for timing)
ticking sounds can also be heard from the vacuum switching value near your intake. hmm... which coincidentially is part of.... the warm idle control system.
Old Apr 5, 2007 | 03:49 PM
DynomyteSW's Avatar
i believe the fuel injectors make a clicking noise as well.
Old Apr 5, 2007 | 04:10 PM
amdforever's Avatar
Yeah its normal Daniel. My 07 has the same "ticking" type of sounds when it idles, both cold and warm, its just the valve springs ticking at low idle, from what I have been told, makes sense as there is nothing wrong with my motor b/c it would have blown by now by the way I drive
Old Apr 5, 2007 | 08:50 PM
Sleep3r's Avatar
toyota's sound like that its normal
Old Apr 5, 2007 | 10:34 PM
boostaddict's Avatar
what oil are you using? toyotas are very sensitive with the VVT-I the 4 cyl not as much but some what. i know the 8 cyl will through a VVT-i code if its real cold and have the wrong oil.. sorry off topic but if your using something not recomended by toyota you may experiance issues, i havent seen any with that 2.4 but idn your conditions, those 2.4 are loud neways
CuRiOuSfIsH's Avatar
Default Re: noisy motor
tC's aren't quiet at idle it's normal. And yeah, a lot of current cars out there are more quiet.
Old Apr 5, 2007 | 10:38 PM
redwar1441's Avatar
its called the toyota tick. I used to spend half my day explaining it to customers. Its normal. If your still wrried go to the dealer and ask to listen to another car, it will sund the same.
Old Apr 6, 2007 | 03:47 AM
DANIEL209's Avatar
thanks,i appreciate all the serious answers.my buddy heard it and told me the same thing it's the injectors.makes sense.
hondajt
Dec 14, 2015 12:54 PM
crimson_sinn
Sep 25, 2015 09:41 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
kfisher8
Aug 14, 2015 03:21 PM
excessads
Jul 13, 2015 11:41 AM
