OE Injector and Fuel Pump Specs
this help?
Fuel pressure: 304 to 343 kPa (3.1 to 3.5 kgf/cm2, 44 to 50 psi
Fuel injector: Resistance at 20°C (68°F) 11.6 to 12.4 Ω
Injection volume 76 to 92 cu. cm (4.6 to 5.6 cu in.) per 15 seconds
Difference between each cylinder 16 cu. cm (1.0 cu in.) or less
Fuel leakage 1 drop or less per 12 minutes
Fuel pump: Resistance at 20°C (68°F) 0.2 to 3.0 Ω
ENGINE SPECIFICATIONS
Type: I4, 2.4L, chain-driven DOHC, four-valve, open deck,
aluminum block and head
Displacement: 2362cc (144 cid)
Bore x stroke: 88.5 x 96mm (3.48 x 3.78 in.)
Horsepower: 160 hp @ 5,700 rpm
Torque: 163 ft.-lbs. @ 4,000 rpm
Compression ratio: 9.6:1
Emission control: EVAP
Fuel system: MPFI
Fuel pressure: 44-50 psi @ idle, 21 psi hold
Fuel injectors: 11.6-12.4 ohms
Oil pressure: 4.3psi @ idle, 36-78 psi @ 3,000 rpm
Valve clearance: Intake, 0.008-0.011 in. (0.19-0.29mm); Exhaust,
0.012-0.016 in. (0.30-0.40mm). See Technical Notes.
Spark plug gap: 0.039-0.043 in. (1.0-1.1mm)
Firing order: 1-3-4-2
Ignition timing: 5°-15° BTDC @ idle
Base idle speed: Manual, 650-750 rpm; Automatic, 610-710 rpm
Fuel system: MPFI
Originally Posted by SquallLHeart
searching WORKS!
I had to search a lot for it though.
I think I found this thread on the 12th page, according to my search criteria, lol.
oh btw, i'll be using your service soon ^^
I need my TBL done =D
Originally Posted by soros151
AWSOME! SOMEONE USED THE SEARCH BUTTON! They should give him a ScionLife sticker for free!
I'm on this freaking website so much >.<
Its comparable to my addiction of world of warcarft
GetSlideways
Scion xD Drivetrain & Power
Mar 16, 2015 11:30 PM
