oil and filter
i just reached around 4500 so im changing my oil. is there any recommended filter that i can pick up at a local store. also what size is the filter. and i was thinking about running full synthetic in it. can anyone recommend a good full synthetic oil that can be bought in a local walmart/pepboys/avanced auto parts/autozone thanks!
I personally went with Mobil 1 Full Synthetic oil and a Mobil 1 Oil Filter (extended performance).
All comes down to personal prefrence. Some ppl will do Royal Purple all the way, some Mobil 1 blah blah. I will be switching to Royal Purple I THINK when my next oil change is due.
Oil filters:
mobile 1 extended performance, k&n, royal purple (made by same manufacturer), Amsoil, pureone. In order
Synthetic Oil:
Pennzoil Platinum (cheapest best protection money can buy)
there's a $15 rebate if u buy 5 qts, in other words $1 qts. Look at the Pennzoil website to print coupon.
Mobile 1 oil shears a bit , no likey.
http://www.bobistheoilguy.com/forums/ubbthreads.php
read-on my friend, look at the UOA for gasoline passenger cars.
Synthetic Oil:
If your motor isn't heavily modified, you can run the Toyota synthetic blend with a Toyota filter for the life of the vehicle with no side effects. If you don't use that, then I would suggest any of the above oils because they are all greater than OEM. Unless you go turbo or S/C or N20, there isn't any reason to worry. Toyotas from the early 90's that only ever ran on conventional oil turn 300k or more on stock motors and tranny's. Great motors live long lives.
what weight pennzoil oil do i use? and if pennzoil and mobile1s the same price ( gpop claims that he found them for 5 somthing a quart for both of em..) wich one is the better buy
Toyota Oil filters are the best! There is a thread that shows a comparison of the filters out there.
Oil geez um it dont really matter as long as you change it when your supposed too. I always run synthetic cause i run my car hard. I have used mobil1, castrol synthetic, and royal purple. I ddint like royal purple. The engine idled louder and something just seemed off. I went back to mobil1 and everythign was fine. I have castrol in the car now cause they didnt have mobil1 in my wieght but it runs the same. I wanna run pennzoil platinum though cause i have heard alot of good things. I juts gotta find a place that carries it in my wieght sincee i live in key west its a lil tougher.
+1 on OEM oil filters. The parts department here gave me a deal on a 10 pack. TRD sparks does the same.
Just change your oil regularly and pay attention to it. That's way more important than nitpicking over which brand.
Royal Purple & OEM filter. bought the 10pack from TRDSparks for me and my GF (she drives an 09 Camry). ive been running it for a good year or so and the car feels good. better than when i had Mobil1 oil.
