P2716 Code on 2AZSC M/T ECU Manual with S/C
Hi, i have a big question, i have this Code (P2716) for automatic trans on my Manual S/C ECU, i also have some other codes related to auto trans NOT Manual, that always come back i assume because A/T & i have M/T.
I try do clear them with no good results. thats on my Supercharger ECU but if i plug the original NON S/C ecu i dont get any code but the car runs like sh%^$ because is not tuned for S/C & 400cc TRD injectors,
but the S/C ECU runs OK but with the codes.
Any idea on how can i fix this????
p.s.
here r all the codes that i can't clear, total of 7:
P2716
P2770
P0713
P0748
P0778
P0793
P0983
p.s.
P2716
P2770
P0713
P0748
P0778
P0793
P0983
P2716 Pressure Control Solenoid "D" Electrical
P2770 Torque Converter Clutch Solenoid Circuit High
P0713 Transmission Fluid Temperature Sensor
P0748 Pressure Control Solenoid "A" Electrical
P0778 Pressure Control Solenoid "B" Electrical
P0793 Intermediate Shaft Speed Sensor
P0983 Shift Solenoid "D" Control Circuit High
all your fault codes are related to open or high resistance in sensor or solenoid circuits.. simply.. your supercharged flashed ECU is for an automatic trans... its looking for these sensors and solenoids and doesn't "see" them, so it attributes it to either a open (YOUR devises are not there) or high resistance...
Did u end up getting this fixed I no its an old thread. But I got a 2AZSC M/T ECU just wanted to know if they all do this when replacing. I got a 06 MT tC
Replacing my stock non TRD. To an ECU that has 2AZSC M/T will I get the same codes I haven't installed the S/C yet.
And is this ECU.( 2AZSC M/T) For the S/C I can't seem to find much about it. I just wanna make sure. Be4 I install
-Sent From DarkSide sense 4.0 Using tapatalk-
ColonelSanders85
12-09-2020 09:44 AM
eatcrispycreme2
01-30-2015 03:43 AM
fur_pig
Scion tC 1G ICE & Interior
01-27-2015 12:52 PM
rcflyer15
12-05-2014 05:15 PM
