Passenger Side CV Axle Support Failure
Old May 29, 2012 | 09:26 PM
s_rhabb's Avatar
Team Scionara
Default Passenger Side CV Axle Support Failure
I was driving and the CV Axle support pulled away from the engine block broke the 3 bolts and stripped the holes. Am I the only one this every happened too?
Old May 29, 2012 | 09:32 PM
dropzone's Avatar
What was going on at that moment the axle failed? Is the car lowered, by how much?
Old May 29, 2012 | 10:06 PM
thendawg's Avatar
Wow thats crazy - that bracket is thick cast steel and held in place by 3 10mm bolts, something crazy mustve happened to do that... I wonder if maybe the bearing in it siezed up and the rotational torque broke it?
Old May 30, 2012 | 11:39 PM
s_rhabb's Avatar
Team Scionara
I think the torque from the power the motor is making simply sheared the bolts. The carrier bearing is fine on the passenger side cv, I think its just from when the torque transmits down the axle shaft it pulls the bracket away from the blocks somehow. I am running about 12 psi and I have an LSD in the transmission. I have the car in a shop now. They are re-tapping the holes where the bolts go and putting on a new bracket. After that they will do some welding to strengthen the support. It either that or get a new block. This fix is costing me $1300.
Old May 30, 2012 | 11:48 PM
thendawg's Avatar
My car makes over 600whp/wtq, so I doubt its a power issue. My cars went through several launches on slicks along with wheel hop thats killed a couple trans, never had an issue with that mount though. $1300 for that fix is a bit high. All you really need to do is remove the axle/bracket, helicoil the threads, and reinstall the bracket with new bolts. Prob have to use a 90* on the drill do to limited space, so def a pain in the ___, but aluminum machines really easy so it shouldnt be that bad.
xBSciontist
Jun 18, 2019 03:06 PM
elwaylite
Apr 30, 2015 02:31 PM
jtucker7
Apr 8, 2015 05:41 AM
black2011tc
Mar 9, 2015 11:02 PM
mischadoll
Mar 9, 2015 05:48 AM
