Pulley Owners Stand Up / Update
I think that the pulley might be also inclueded in the law, but I haven't check. http://www.semasan.com/main/main.aspx?id=61713
Maybe there is something on that in here. I was just pointing out that its better to take out the pulleys everytime, just to have less **** problems from your dealer.
Guys, I got the underdriven only to see if there are really any problems with the alternator while using these, which I higly doubt. Got it from NST and the quality from the pulley is AWSOME! Now for some testing. I have an xbox on my car and I will see if there is no problems with it, without having the overdrive alternator one.
changing the pulley on the supercharger, intake, BOV, header, or anything that has to do with the supercharger will void the warranty on the supercharger. I was told that by Maita Scion. I believe it was also stated in the papers that came with the supercharger. It doesn't matter if the modification has anything to do with the problem that you are having or not. TRD will NOT warranty the supercharger anymore after noticing any modification.
ok so im powering a 2 channel amp and a small sized computer... if I dont get the alternator overdrive pulley, will I notice a problem?
also, with the alternator running slower, wont that cause other car electronics to fail or have the battery die sooner?
We are not talking about the supercharger here people. It is only about crank pulleys.
And mike6789k...
Here is what NST told me about the overdriven alternator Pulley.
And mike6789k...
Hi Eddie,
Thank you for your interest in our site and products, we appreciate it.
You will be ok with our Underdrive Crank Pulley (NST02020) and your Xbox! We
have had many customers with mild stereo systems, upgraded lighting, and other
mild modifications use this pulley with great results.
Our accessory pulleys are used more so for further weight reduction and a bit
more performance. The only time our Overdrive Alternator Pulley becomes a
necessity is if you have something like a 3000+ watt stereo system and extra
lighting in your car!
Thanks again for your interest in our site and products, we certainly do
appreciate it. Good luck and have fun with your project!
NST Customer Service
www.NonStopTuning.com
Quoting Eddie Vega <soros151@gmail.com>:
> Hi I was just wondering if I could safely use the Scion tC underdriven
> pulley without the 20% overdrive alternator pulley and still have no
> problems with the xbox I have in my car. I do not have anything else that
> would draw a lot of current, but I was still curious since I use an inverter
> to power up my xbox. Will it matter if I only get the underdriven pulley? I
> don\t always use the xbox, so it's not powered up all the time.
> Eddie Vega
> Scion Evolution
> Public Relations, Mayaguez Region,
> Puerto Rico
> Eddie Vega
> Scion Evolution
> Puerto Rico
Well, I see it like this, the less weight you get out of there, the more freely it all can move. Remember, I'm not responsible for anything done here. It sounds weird when someone actually calls me by my name here in the forum.
