Pulley Owners Stand Up / Update
Originally Posted by jjos1
Originally Posted by CuRiOuSfIsH
Originally Posted by -TeMpEsT-
Well said soros. My Agency Power pulley is ordered. It's good to know that so many owners are speaking about their experiences with different setups and that the 'rumor mill of my brother's friend's cousin in-law's sister's wife's uncle had his engine 'insert random destuctive event here'" has been avoided in this thread.
Lets say Toyota designed the 2AZ to last up to 100K miles. The pulley may shorten the life by 1K mile, 3K mile....... nobody knows yet. But as of now, things are still ok.
And, for example, forced air induction has been the cause of many an engine failure but we still seem to be turbocharging and supercharging engines all the time.
ANyhow, almost 1K miles w/ AP pulley on 07. Everything fine and dandy. I have been mashing the gas pedal more recently b/c of the colder weather.
I'm at 30200 and about 21K+ on the pulley................still going strong and I've punished it the past 2 tank fulls trying to get to where I go as fast as possible
......still getting 26+ mpg and average coasting highway speed is about 80-90 on I-95
Just got the NST set put on last night....i had some weird idling vibrations later the night that seems to go away but other then that.....the response is quicker....you can feel a decent change....i will be monitoring idling and anything out of the norm and keep you guys posted.....
on a side note the front sway was put on as well and kicks a$$....car is tight
~23K on the pulley and nothing. Installed my Tanabe NF210s Saturday and thought I would take a look to check for any leaks or cracks.......no oil leaks, no cracked oil seal, no deformation of the pulley. All is good
Anodized ZPI would be good....stronger and same weight. Both free up excess "drag" on the crank......they don't "produce" power though. The just free up drag which CAN help the engine work more efficiently.
I think NST is still a slight decrease in size compared to ZPI....not 100% sure though. NST will be a hair lighter if it is a little smaller....honestly, nothing that will be anything noticeable.
nonono...the nst stock sized one
this is the one i'm referring to...
https://www.scionlife.com/forums/vie...r=asc&&start=0
If it is truely the stock size, then either or will be fine (same weight... ~1.1 lbs).....but, check Non Stop Tuning's site....there's no "stock" size pulley....it's only a 20% underdrive pulley and requires a different belt.
http://www.nonstoptuning.com/pKitToySciTC.htm
The picture on the site you have is the same one as on the NST site itself......I would double check to make sure it truley is the stock size pulley.
