Random ECU hiccup?
Old Aug 8, 2007 | 08:52 PM
Mugetsu's Avatar
Default Random ECU hiccup?
I got a DTC for
PO606
thats a toyota PCM processor fault code
pretty scary...
even stranger, there were no pending codes.
All I have H/full 2.5 exhaust
no kind of electronics, the car is running fine, i had a stupid WR ignition coil equawutever installed so i took it off and reset the ecu and the code has not returned(as of yet, about 100 miles) BUT i had the WR thingy on for almost 6 months with no probs...
any ideas?
Old Aug 9, 2007 | 02:32 PM
Mugetsu's Avatar
Bump
no one has had this code show up?
maybe i should see if the guys in F/I have seen it.
Old Aug 10, 2007 | 12:07 AM
toyota_scion_tc's Avatar
Did you do any mods on your secondary o2 sensor for the cel? I tried a o2 sim and I got a similar code.
Old Aug 10, 2007 | 02:49 PM
Mugetsu's Avatar
Holly $#%@!
yes i did.
I extended the second(narrow band) O2 sensor...
I cut the oem harness in half then used 4 pieces of wire about 2.5 foot long to extend it.
BUT i soldered and shrinked AND used that flexible ribbed sleeve on it.
BUT(again) i did notice the AC drips and runs down it.
On high humidity days(the CEL came on in the morning) i guess moisture could get in there and cause a short.
Hey man THANKS a million! you really helped out here, now at least i have an idea what could have caused the CEL.
I'm gonna check that sensor.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
deademon
Mar 31, 2016 09:25 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
JoggerFogger
Photography & Video
Jul 27, 2015 09:34 PM
