Rattle in Drivetrain Area
So, to start out I just rebuilt my engine as well as getting a new clutch and lightweight flywheel. After putting everything together it started up with no problems. Drove for about 150 miles without a problem. Now when I'm driving I hear a really faint rattle. If I'm going over 55 and then let off the gas it gets fairly intense. As soon as I have the clutch engaged the sound goes away. So I think it's something to do with the throwout bearing that I replaced possibly. Any help is appreciated.
Which clutch and which flywheel? I've had similar noises coming from under the hood as well since around 75k miles (just broke 90k yesterday). Using an Exedy Stage 1 clutch and Fidanza LW Flywheel. There are (2) different noises I hear:
(1) a rattling or knocking sound when idling. I've heard that it may be the clutch fork hitting against the throw-out bearing. Noise goes away when the clutch is depressed.
(2) a rubbing sound kinda like rubbing sandpaper. This only happens when I let off the clutch (cruise) above about 40 mph and in 3rd, 4th, or 5th gear. Have heard from both Fidanza and Exedy that this is normal (?)
Will be installing a new clutch Friday as well as replacing the wear pad on the flywheel. Hopefully those noises will go away.
Is it an older version of Competition Clutch or did you buy new recently (like within the last month or two)? If it's an older design, these clutches have had lots of quality problems. You may want to have it checked out in case a spring broke loose or something.
I recently bought a stage 4 from Competition, but it's the newly redesigned one. They claimed to have worked out a lot of the previous design flaws. Fingers crossed!
Contact CC and ask them about it. Could be nothing.
You can try to go back to where you got it installed (unless you did it yourself) and see if they'd be willing to check it for free or reduced cost.
Hmm...I did the install myself. :/ Torqued everything to spec. I'd be pretty upset if it's broken already. Only put 400 miles on it so far. I guess I'll have to do that. I'm wondering if it's a bad throwout bearing?
I did some research on this a few years ago and its seems like some lightweight flywheels do make that chatter noise. Nothing you can do about it. I've had my CC stage 4 clutch and 12lbs flywheel installed by toyota dealership and it has been doing that noise for almost 60k miles. So used to it that doesn't even bother me anymore.
Prolly the sound of your trans screaming in pain and you swerving outta control. Not tryin to be negative or xtreme, but you'd know right away and would probably cause a much bigger, noticeable problem when it happens.
Definately won't be drivable. It'll be stuck in one gear.
the trans wouldnt be screaming the bellhousing and what ever the spring is hitting is what would rattle, and no this will not cause you to loose control...
mischman
Sep 15, 2015 03:38 PM
