rough idle and stalling
ok so the other day i was driving and my car started like sputtering really bad, and it was really hesitant, and then later on down the road goin like 45 i put it in neutral and it stalled, anyone kno wat the problem is? i was thinkin a sensor or somethin but plz help.
Any Check Engine Light? Will it start or just sputters and stalls again?
Have you tried to disconnect the battery (to reset the ECU) and let it idle for a few minutes? If you have a CEL, get that read first though.
pull the trouble codes and make sure you only have a code for your header, which should be the code for deficient cat or something. you could have another problem that you're not aware of because you have been ignoring your CEL for some time.
well seein that wen you put a header on your car it throws an intake on your car its gonna do that because y0u are deleting your cats, got it checked today and there was nothing wrong. its runnin perfectly fine.
steeze69
05-24-2021 02:57 AM
Luisfc1972
09-30-2015 12:22 PM
