Shifting Problems
Old Jan 16, 2010 | 08:24 PM
fmtc4ever's Avatar
Default Shifting Problems
So I replaced my clutch on August 2009 with a Clutch master stage 2 and Fidanza flywheel and redlide mt 90 but since then ive been having problems with shifting...i have to let it warm up for at least 20 minutes in order for it to shift....somethimes it takes more time and its realy but really hard to shift....Im in NY if anyone wants to help me please let me know thanks
Old Jan 16, 2010 | 09:15 PM
my06tc's Avatar
its the redline mt 90..get some eneos gear oil.......i had the same issue..
Old Jan 16, 2010 | 09:17 PM
fmtc4ever's Avatar
but its mad hard to shift,,,,do you think is the gear oil????
Old Jan 16, 2010 | 10:42 PM
my06tc's Avatar
yea i know i had the redline gear oil also for about 3,000k miles it was good at first but then it got really bad..wouldnt go into gear right.. grinding and etc.....theres a whole thread on this in the tech area about redline and people experience with it...im using eneos gear oil its like night and day from redline to eneos....and yea most then likely its the gear oil......the only way to actual tell if you change to eneos or amsoil
How many miles do u have and what year is your tc
Old Jan 17, 2010 | 12:40 AM
alienvictim's Avatar
actually my06tc is probably correct. in a hurry i replaced the tranny fluid with the wrong stuff on
my 90 300zx. wouldn't go into gear to save my life until it was up to temp couldn't figure it out to save my life.
was almost about to tear my tranny apart. and than glanced over and read the label on the fluid again.
forehead smacking time. anyways i believe he is correct about changing the tranny fluid. and really it
wouldn't hurt to change it out and see if it isnt something really bad like a throw out bearing going out.
Old Jan 17, 2010 | 01:03 AM
fmtc4ever's Avatar
thanks guys im about to but motul 300
Old Jan 17, 2010 | 01:43 AM
Blue_TC_Man's Avatar
umm I doubt its the mt-90, if you used MTL maybe but, I have had MT-90 in my car since I got it with no problems at all, and I drag race the car very often, and drive it hard.
When you say it is hard to shift do you mean it acts like the synchros want to lock you out, or it just grinds then pops in?
Old Jan 17, 2010 | 03:29 AM
fmtc4ever's Avatar
Its really hard like i cant get my car into gear at all and when i do and shift to second or third or whatever its hard and it grinds
Old Jan 17, 2010 | 03:40 AM
does it do that if you blip the gas? blipping is when you pop the tach up to match the speed the next gear would normally be on the tach.
usually if the syncros are going out your tranny will shift this way.
say your in 3rd and you would like to shift into second. your rpm levels in 2nd are way higher. than before down shift you would tap the gas bringing the tach up to the rpm required to have the tranny slip into second.
works when up shifting too, good way to see if it is a synchro.
Old Jan 17, 2010 | 04:04 AM
weezyfbayba's Avatar
u have to adjust the clutch pedal up a little and ull be fine... look it up there is a thread for it..
Old Jan 17, 2010 | 04:06 AM
that's a possibility but wouldn't that mean his clutch is failing or really needs replacement?
but that does sound like a real answer.
Old Jan 17, 2010 | 07:01 AM
yeah it sounds like your clutch isnt being depressed all the way
Old Jan 17, 2010 | 12:09 PM
ur clutch isint engageing all the way... adjust it up then report back here and thank me
Old Jan 17, 2010 | 03:04 PM
fmtc4ever's Avatar
thanks guys but one more question
Can i do the pedal adjustment myself???
Also i cant find the thread for it
Old Jan 17, 2010 | 08:54 PM
yes its pretty simple and there is a thread.... my boy made it so keep looking....
NonStopTuning
Jun 29, 2015 07:42 PM
08bakerXxtc
Mar 19, 2015 09:51 AM
annika
Mar 16, 2015 06:36 PM
disaster06
Feb 3, 2015 08:50 PM
DerekMarq
Jan 27, 2015 02:38 PM
