Throttle Body Changeout
Hello All, New to the forum. I have an early edition '06 TC with a bad TB. I understand that to replace one the computer has to 'learn' the new unit. Correct? How does this occur/happen? Is this a dealer only process or can it be done in my home garage?
TIA,
Lennecke
TIA,
Lennecke
But I dont believe you'd need anything from the dealer, I've never heard of them doing anything special, and there isn't anything in the service manual about it. It just says to drain the coolant (hoses go in/out of the throttle body) and replace the throttle body, replace the coolant (short version).
so what happened to your early '06? did it throw a check engine light? what were the symptoms that caused you to replace the throttle body? just wondering.. oh and welcome to the forum!
ScionTC - Yeah, got 5 codes! P0121, P2103, P2111, P2112, P2111.
P0121 - Throttle/Pedal Position Sensor/Switch ”A” Circuit Range/Performance Problem.
P2103 - Throttle Actuator Control Motor Circuit High.
P2111 - Throttle Actuator Control System – Stuck Open.
P2112 - Throttle Actuator Control System – Stuck Closed.
P2111 - Throttle Actuator Control System – Stuck Open (listed twice).
Car starts OK, but initial idle is about 2K. Comes down to around normal in a minute or so. Can't give any 'real' gas, have to be controlled and steady to drive at all. Can only do about 40 MPH (limp home mode). Some times I have no throttle response at all. Car is an '06 built in 9/05, manual trans, with 38K.
Thanks for the welcome.
Lennecke
When I bought my car I had to swap the motor... old owner found out 17 pounds of boost on stock compression with baseline tune = not good.
The motor I bought was out of a auto of the same year. I didn't swap the throttle body thinking it should be fine. It ended up driving a bit funny, rev matching wasn't smooth. rolling the clutch out was a bit odd. If I held the peddle steady it would fluctuate at lower rpm's. Needless to say I swapped out the throttle body and the driving was a whole lot smoother.
Lennecke
Lennecke
here is the number and description:
SB0012-10 Fuel System - Throttle Body Update
The part number has changed for the throttle body
BODY ASSY, THROTTLE W/MOTOR was part number 22030-28060
Replaced by part: 22030-0H021
price? ouch.. List price $901, trdsparks.com (dealer people buy from on here) $694.17 or you can take a chance on a junkyard part? I just looked up junkyard parts.. $200-300! And who knows if those parts might not have the same issue that you had before. Toyota changed the part number so the part has changed, sounds like they revised it from the earlier part.
hope that helps.
Sorry to bring up a buried thread but I had this exact same problem a couple of days ago. One evening my car threw the P2111 code (throttle actuator stuck on open), and the revs on idle (I have an automatic) were unsteady and the car was vibrating. I drove it to work the next morning and I lost all power on the freeway and had to coast to the shoulder. Had to get it towed to pep boys and they said I had to replace the throttle body...since my car was dead I had no choice but to pay their costs, all told being $1350. I have an '06 with 55,000 miles and have had literally zero problems with the car since I bought it in October 2005. Any idea why this happened and how common it is?
Blunderbuss
Oct 8, 2015 04:56 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
