Transmission stuck in parking...
I tried to drive my 05 Tc for a ride this morning and opps... I couldn't move a **** from P. Parking brake was on before. I don't know if it matters but few hours prior to that I was changing my tail lights. SEL isn't on - no messages what so ever. Anyone has any ideas? Does it have anything to do with fuses? TIA
could be, if the car doesnt know that the brakes are on, it wont release the shift lock. check your fuses and your wiring of the brakes lights. make sure the connections are sound as well as grounds.
When you blow the fuse. You can't engage the shifter. You can 'override' the lock by opening little tab
by the shifter. (Although I would not advise it because you will have no rear brake lights!) This is also
in your Manual. Glad you fixed it. Next time, do what I do; working on anything electrical, pull out the
fuse(s). Makes life A LOT easier.
BlingSlade
Sep 5, 2015 08:52 AM
