TRD intake and TRD High Performance Air Filter
Old Apr 23, 2009 | 02:18 AM
tico4csun's Avatar
Team ScionTific
Default TRD intake and TRD High Performance Air Filter
Can these both be installed or it can only be one and not the other?
Old Apr 23, 2009 | 02:25 AM
ack154's Avatar
One or the other. The TRD air filter would be a drop in filter (Like a K&N) for the OEM airbox.
Old Apr 23, 2009 | 02:27 AM
tCtCtC's Avatar
One or another. The high flow filter goes in the OEM intake, where the intake is a full replacement.
tico4csun's Avatar
Team ScionTific
Damn so both can't be used at the same time??
Old Apr 23, 2009 | 02:28 AM
tico4csun's Avatar
Team ScionTific
Got it, I'll just get the filer then. A much cheaper alternative.
Old Apr 23, 2009 | 02:33 AM
ack154's Avatar
Well the TRD intake is a complete cold air intake (which has a "performance" type filter on it) and replaces the OEM airbox entirely. So there's no possible way you would be able to use both. Completely different types of systems.
The TRD intake would be the better of the two for sure... and honestly, I'd say don't even bother with the TRD filter though - you're not going to notice any performance gain from it. There might be one... but it would be minuscule and not noticeable.
Old Apr 23, 2009 | 02:35 AM
203superwhitetC's Avatar
go with injen. a lot of people run it on here.
Old Apr 23, 2009 | 02:55 AM
istoppedpre's Avatar
no experience at all with the trd but i've got an injen and i tell you its a really awesome product. noticeable gains, amazing sound and the fact that you can use it as a short ram is very convenient especially if you live in colorado where there are huuuge puddles from melted snow just waiting to hydrolock the car. but really its up to you. i nabbed my intake for 200 and i haven't really seen the trd for much cheaper
Old Apr 23, 2009 | 11:07 AM
SFTifoso's Avatar
Please don't buy the TRD air filter. It's the most useless thing you can buy for your car. It's hard to clean. Then it's almost impossible to tell if you've oiled enough, or not enough, or too much. Also if you hold it up to the light you can see some pretty sizable holes (for a filter) in the filter media. Just save your money and buy a true cold air intake, or just change the oem filter frequently to maintain performance.
Old Apr 23, 2009 | 11:36 PM
tico4csun's Avatar
Team ScionTific
If I even two take the intake route, I'm sticking with trd. I ain't about to void the warranty.
Old Apr 24, 2009 | 02:19 AM
chicotunner07's Avatar
how exactly did you clean yours? lol
use oxi-clean, carbonated water, in a bucket, swirl around, rinse with very low pressure water(if you use any amount of pressure, you will make holes in the filter media) and let airdry, the filter will be white, you are done oiling when its evenly red!
sorry to be off-topic, but that is the most effective way of cleaning oiled filters!
to the OP, i say go Injen if you want a little performance, but the TRD is definitely the best looking CAI in my opinion!
Old Apr 24, 2009 | 03:20 AM
DJ08tC's Avatar
Just because you get the TRD doesn't mean it won't void your warranty, if you install it yourself and it causes a problem they can void your warranty. That is why you should consider going with an injen or another one that is cheaper because they will have to prove it caused the problem. Unless you are getting the dealer to install it.
Old Apr 24, 2009 | 05:36 AM
tico4csun's Avatar
Team ScionTific
I know peeps at the dealer. 'Nuff said. And for those who replied, thanks again for your time.
Old Apr 24, 2009 | 02:55 PM
SFTifoso's Avatar
I never thought about cleaning it in a bucket. I just followed the instructions on the cleaning kit. I sprayed the solution on the filter, let it sit for a few minutes, then rinsed it out with low pressure water. Still though, I'm sticking with dry filters from now on. There really isn't much difference among oem and performance filters as far as airflow goes.
Old Oct 23, 2009 | 04:25 AM
HOLLOWMANGT69's Avatar
I have the TRD CAI and its been great so far. I havent cleaned it once but i'm sure its long overdue for a replacement. Anyways I was looking around and have been seeing people talking about replacing the filter off the TRD CAI and putting a "AEM Dry Flow Air Filters". IF I were to get the same size filter as the TRD CAI filter, would it be better ?
Old Oct 23, 2009 | 04:56 PM
omgu8myrice's Avatar
installing an intake wont void anything except if something goes wrong with your intake. even if it causes hydrolock, your trd intake wont be covered by warranty even if it is installed by the dealer. theres really nothing else than can possibly go wrong
Old Oct 23, 2009 | 05:03 PM
elcapetan's Avatar
install it yourself its cheaper
JPuehl
Jan 10, 2015 01:01 AM
cid_mcdp
Jan 5, 2015 02:45 PM
Godfryness
Jan 2, 2015 11:18 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
hotroddelux
Dec 3, 2014 11:33 PM
