Unichip Numbers Released
I was checking out Unichip's website and noticed that they have dyno's up for the tC. Looks like they have to 2 pre-set maps available for their PnP unit for the tC. A map for stock setups, and a map for vehicles w/ a header an exhaust system. What concerns me is that they have it listed as a TRD header and TRD catback exhaust, of which TRD offers neither of. I'll email them shortly regarding this to see if there's an explanation. But whatever header and exhaust they did use to dyno test, showed a power loss across the entire powerband over stock before the Unichip.
Barring those discrepancies, the gains for the stock map look very good, with an avg. gain of 5.4hp and 5.6 lbs-ft of torque across the powerband, and a max gain of 14hp at 6500 RPM. Please note, that these dynos show data corrected for flywheel values , not at the original numbers from the wheels. Looks like the dyno they used could possibly have had too high of a correction value.
Originally Posted by jmiller20874
Why are the stock numbers so high? 176HP, yeah I wish.
Originally Posted by English
I don't think the correction % was too high...I mean with headers and exhaust and chip to gain 16 hp...that's not unreasonable
I called a UNICHIP dealer today and he got me all the info on it. It is $915.00 and will be for sale May 15th. The unit is plug and play with no wiring required so you can install at home and any UNICHIP dealer can add programs to it later because they said programs will be released for the TRD Supercharger which will show some decent gains. The unit plugs in and you scroll through it and pick what parts you have installed so that it can adjust the maps accordingly and any authorized UNICHIP dealer should have a computer to add maps in and do adjustments as needed.
isn't 1000 dollars a little steep? aren't chips usually in the 3-400 range? or is that just for hondas?
i don't know that 16 flywheel horsepower is worth a thousand dollars, on this engine anyways.
i have to say, don't waste your money on the unicchip. they did a group buy on the unichip on matrixowners a while ago and after posting dynos numbers people were excited. no one (that i remember) could duplicate their dyno numbers and would come in under. people thought it was a worthless mod.
Originally Posted by SupaWhiteTc
It may not be that great on NA but with the TRD S/C it will add a bunch because on the Corolla-S with the TRD S/C it added a lot of power.
maybe it can adjust your timing or vvt-i or something too...
as for what it does, it works like a greddy e-manage. it is basically a piggy back system that is supposed to help, but i haven't see many good reviews on it.
this is what unichip has posted on their site about it
What Is The Unichip?
The Unichip is a computer that electronically resides between your car’s ECU and engine, releasing 100 percent of an engine’s untapped power. Sold worldwide for more than a decade, the Unichip is a tested and proven engine performance product used on the street, racetrack, and in off-road applications
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
