weird sound
Old Dec 8, 2007 | 09:59 PM
przemko's Avatar
Default weird sound
hey guys i need some help from you
yesterday when i was driving home i've noticed a weird clicking sound coming form under my hood when i opened it up i could heard this clicking sound on the right side of the engine bay where the transmission is ( driver side )
Any ideas what it can be it's pretty loud clicking so i getting woried and i do not know what it can be any ideas
Thanks in advance oh my tc is automatic
Old Dec 8, 2007 | 10:04 PM
andyxtc's Avatar
i got the same problem! except the sound is coming from the passenger side
Old Dec 8, 2007 | 10:52 PM
przemko's Avatar
mine is coming from the driver side for sure so it's not conected with belt or pulley
Old Dec 8, 2007 | 10:58 PM
tC-Collin's Avatar
Scion Tuners
its a bomb. thats why you dont make enimies. sheesh
Old Dec 8, 2007 | 11:05 PM
yeldak's Avatar
VVTI
Old Dec 8, 2007 | 11:08 PM
przemko's Avatar
what do you mean vvti
Old Dec 8, 2007 | 11:09 PM
tC-Collin's Avatar
Scion Tuners
Originally Posted by yeldak
VVTI
Old Dec 8, 2007 | 11:25 PM
yeldak's Avatar
VVTI makes a clicking sound.
the passenger side noise could be a loose pulley.
Old Dec 9, 2007 | 02:59 PM
boostaddict's Avatar
its a vsv on the air box for emissions the canister control valve. it will make a loud constiant click go away them do it again. its normal
Old Dec 9, 2007 | 09:38 PM
andyxtc's Avatar
loose pulley? is that bad -_-
Old Dec 9, 2007 | 09:41 PM
Blackmagix's Avatar
lol yeah, go get it checked out
Old Dec 9, 2007 | 10:00 PM
qrymson's Avatar
i got the same transmission ticking. only at idle (auto), when i depress the gas pedal lightly to accelerate, it goes away. that's in a quiet parking lot with slow accel. driving at speed can't tell. road noise and all. started happening about a month ago. owned it new since 2005. yesterday after a 3 hour drive, as i exited the highway CEL came on. going to shop this week. will update on this next week
Old Dec 10, 2007 | 11:11 PM
przemko's Avatar
the thing is that i have injen cai so no air box in my car my cel is on but i have header so no idea if anything else might be wrong
maybe it will sound like a stupid question but were can i check my codes can i do it at auto zone or any other shop
Old Dec 10, 2007 | 11:14 PM
tC4italy's Avatar
there are a few threads about this. I'll summarize it.....
automatic tc
same noise (and no it's not the usual VVTi clicking noise since I compared it to another auto tc) extremely loud from engine bay
comes in especially at idle
went to the dealership 3 times
1. diagnosed intermittent valve sticking...uhm ok they supposedly put a cleaner but the noise stayed there
2. possible injectors issue...again ok fix it?
nope
So I got a S/C instead replaced the injectors so no more noise
Old Dec 11, 2007 | 08:46 AM
przemko's Avatar
ok so the clicking sound occurs only when the engine is warm when it's cold right after the start i could hear any clicking
any queses
Old Dec 11, 2007 | 01:13 PM
BrEaK_AwaY's Avatar
VVTI = Variable Valve Timing w/ Intelligence. That is probably the noise you are hearing.
Is a loose pulley bad? Of course it is. but if you haven't tampered with it, im sure its not lose.
where to get CEL checked. anywhere that has an OBDII Scanner (dealer, auto parts store, etc.). When you scan the car, make sure you write down the number, and look in the book to see what that number means. If you have a header, you are probably going to get a code that is telling you your cat is bad. you should get a anti-fouler and put it in your spipe if you havent already.
Old Dec 11, 2007 | 11:45 PM
przemko's Avatar
i have antifouler but in my case it justr doesn't work so i can rid of cel
i should better go to the dealer to check it out but i hate the service since they f..ked my once
Old Dec 21, 2007 | 02:13 PM
tC-Collin's Avatar
Scion Tuners
one anti fouler usually wont do it. get two of them drilled out with a 1/2 inch put em together then there ya go
Old Dec 21, 2007 | 02:21 PM
rosedaleny806's Avatar
Valve Tick Normal But toyotas have a tendency to have a very loud valvetrain
Old Dec 21, 2007 | 07:20 PM
SLIVER007's Avatar
I have this same noise, but it only happens when i release the clutch, I also have a clicking noise at idle, I think it's the hydralic piston that engages when you push the clutch. It needs to be re-lubed maybe?.
kmouse64
Sep 4, 2015 01:11 PM
Marialzga
Jul 31, 2015 05:38 PM
capgrover
Jul 25, 2015 05:00 PM
kmouse64
Scion xB 2nd-Gen Wheel & Tire
Jul 22, 2015 10:13 PM
Mjdavis1994
Jul 18, 2015 04:29 AM
