wideband bung location with supercharger?
Old 12-18-2009, 02:36 AM
b52hDUNN's Avatar
Default wideband bung location with supercharger?
I have purchased a innovate wideband gauge and was wondering where I should weld in the o2 sensor bung. Innovate manual says to install it before the cat and thats about it. I have read that several people install it on their s pipe but that is for turbo. I still have the oem header with cat.
Should I weld the bung on the header where the first oem o2 sensor is, if so should I weld it on a different cyclinder?
OR
Should I just weld the bung in the s pipe?
THANKS!!
b52hDUNN is offline
Old 12-18-2009, 03:29 AM
Ronin Scion
Ace83's Avatar
you can install it close to your oem O2 sensor or like what innovate manual says.. you should be good anywhere before the cat
Ace83 is offline
Old 12-18-2009, 03:32 AM
Thorium06's Avatar
what would be the possible disadvantages of having it after the primary cat? does it just not give as good of a reading?
Thorium06 is offline
Old 12-18-2009, 04:13 AM
b52hDUNN's Avatar
I got the same question!
b52hDUNN is offline
Old 12-18-2009, 04:17 AM
Thorium06's Avatar
yeah i have just been running mine in place of my secondary o2 sensor, it seems to read fine, but i have a bung i was going to put in soon, so if it makes a difference i wont weld it to the s-pipe like my original intention
Old 12-18-2009, 08:29 PM
b52hDUNN's Avatar
any other thoughts out there?
b52hDUNN is offline
Old 12-18-2009, 09:40 PM
Blue_TC_Man's Avatar
I mean a cat cleans emissions thats the purpose of it. If you put it after the cat it will not give an accurate reading as a lot of the burnt fuel fumes it reads have been removed
Blue_TC_Man is offline
Old 12-18-2009, 11:12 PM
Thorium06's Avatar
well that complicates things for using the oem header, there doesnt seem to be much room above the cat
Old 12-19-2009, 12:36 AM
dont use the OEM header?? or just install the bung under the primary theres room
Old 12-19-2009, 01:17 AM
b52hDUNN's Avatar
I wanted to stay with the oem header. ^may just put it in that location.
b52hDUNN is offline
Old 12-19-2009, 01:41 AM
Thorium06's Avatar
yeah i wanted to stay with the oem header too, as im really close to the sound limits for the events i run, plus i like the sound of it now. il probably just keep it in the secondary bung, it seems to get a decent signal, i never thought twice about it until now
Old 12-19-2009, 01:55 AM
b52hDUNN's Avatar
^ dang. now I can decide... the header will be a pain and the s pipe will be much easier. may just weld it in the s pipe since it is working out for Thorium06.
b52hDUNN is offline
Old 12-19-2009, 02:21 AM
I mean its not really a big deal, but it will be a slightly different reading
Old 12-19-2009, 02:33 AM
b52hDUNN's Avatar
^ I'm assuming you are guessing that it may be a different reading. Guess the only way to tell is to try out both locations.
b52hDUNN is offline
Old 12-19-2009, 03:07 PM
I mean it will be different as cars clean the emissions, how big of a difference, IDK the cat on the header is a precat so it is just an extra cleaning unit, so I dont know how much it actually filters
Old 12-20-2009, 03:30 PM
b52hDUNN's Avatar
any other ideas?
b52hDUNN is offline
Old 12-23-2009, 10:56 PM
b52hDUNN's Avatar
o2 sensor bung welded to the s pipe in front of the oem o2 sensor. Getting good numbers!
b52hDUNN is offline
Old 12-23-2009, 11:23 PM
Thorium06's Avatar
what are you picking up at idle?
Old 12-23-2009, 11:26 PM
b52hDUNN's Avatar
Idle 15.3
partial throttle 14.5
3/4 throttle 12.0
full 10.2
b52hDUNN is offline
Old 12-23-2009, 11:34 PM
Thorium06's Avatar
cool that what i usually get too, exept it seems you run very rich at full throttle, i have it tuned to be around 12.3 and tail down to 11.9 towards the top when i reach 8-10psi
Quick Reply: wideband bung location with supercharger?
