ZPIracing Stage 1 Short block
Originally Posted by tcsciontist
Originally Posted by ZPIracing
****Head Studs are recommend with this package.***
Make a COMPLETE kit, where nothing else is NEEDED..?
Originally Posted by rockbrawler884
What kind of power gain is expected with the 11.1 pistons?
However expect to use a good piggyback, ours is pretty safe considering what's been done with stage-0's, but with most piggybacks like Camcon, youre only garunteed a ballpark map based off what the stocker is doing. To take advantage of the HC, I would look at the new Unichip for your main option, and you would definitely need to use a higher octane. You may be able to get away with 89-91 based off your tuning (a guess), but might need to use premium.
I decided to forego the HC conversion for a more compromised P+P, N/A cams (as a future upgrade), Camcon (I reset on oilchanges), and the basic bolton's. Of course my goal has changed alot and is now a conservative 220 whp, which should be fine on regular (a guess, well see).
The -s, if I remember correctly, has a redline that is about 1500 rpm higher. Peak HP will benefit from this. The two cars are very different in thier setup from what I have gathered. But, I would assume close to that, maybe more around 20 - 25 BHP. But, it is hard to tell without knowing all the variables affected. Once you start changing things in this area everything else changes as well.
VuDism
Aug 18, 2015 03:51 PM
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
