5 inch catback exhaust?
Originally Posted by trust
how the hell did you know what i was thinking? i was actually doing a custom cam setup with the acura tsx cams into the engine, along with some internals from the mustang for more torque, and maybe some forged pistons specifically made for a ferrari. this way, i can run 11's all day and still get like 23 mpg. i dunno if i'm going to patent this idea, so you guys feel free to do as i did.
Why don't you also do it in PVC so it will be more light weight!!
Funniest thing I have ever heard you say.
that's signature material there.
though i don't have enough room in mine... wanna do the honors?
can I have the honor of putting it on my sig?
Originally Posted by SquallLHeart
someone needs to get beat up with a common sense stick.
Originally Posted by dudebrah
and someone said something about true dual exhaust, on an L4 is that really necessary or even possible?
sure its possible... instead of getting a 4-2-1 header... just do 4-2 and then from there split off to 2 seperate front pipes heading back...
Originally Posted by BuddhasTC
p.s. dezod was the 1st to come out with a kit for the 07's and that came out some time ago.
and if your serious. u should get that exhasut then wrap ur stupid lips around the tip, and have a friend start the car up =X
Originally Posted by captainlaziness
Why stop at 5"? I say go all out and do a custom 20".
why dont you just take the hole exhaust system off and runn it completely open.. your sacraficing torque for horsepower.. which in the long run you go faster.. but your slowly gonna get there. versus a quick take off.. and if you do it for racing.. a quick take off seems more important to me
You are not sacrificing torque for hp. HP is a measured result of how torque is applied at a given point on the powerband, period, that is it. So if you sacrifice low end torque, to be worth it at all you need to increase torque higher in the band so you are producing more power there. And engine doesnt produce hp, it produces torque at a given rpm, which we measure by calculating hp. Think of it as an index of how well we are applying the torque at various rpm levels.
And there is much more to it than simply thinking if you cut off the pipe you sacrifice this for this. Exhaust is the most commonly misunderstood thing about performance I think. Exhaust pulse, length and size of tubing, relative length of the header pipes used to utilze the pulses properly and making it all work to produce the scavenging effect you need to get the power where you need it are all things that a true exhaust designer takes into account.
Originally Posted by trdtcpr
Originally Posted by cherryBox
dang... just go jet powered...
i was looking for the same pic to post but couldnt find it fast enough...
*tell me what you think. i can't believe our cars don't come stock like this.
