7.5psi on Stock S/C setup
Old Nov 13, 2007 | 04:11 PM
svrTc06's Avatar
Default 7.5psi on Stock S/C setup
now, dont get me wrong, i like haveing more psi then what TRD told me i'd have.... i just want to know if anyone else has this too.
I just installed my Autometer Electric Boost/Vac Gauge in my S/C '06 Automatic, and i made a full throttle pass when accelerating onto a highway, and according to the gauge i maxed out at 7.5psi??
This is my first f/i car so i dont know if somthing is wrong or not causing the boost to be over 7lbs (stock pulley)
Let me know
Thanks everyone
Old Nov 13, 2007 | 04:16 PM
mitchelltc1's Avatar
I think it's supposed to be 7 at 6,000 rmps, no higher...
Old Nov 13, 2007 | 04:19 PM
draxcaliber's Avatar
nothing to worry or brag about. it is probably just some calibration error.
a couple people with the stock supercharger who use the a TRD boost gauge complain that it says they are only making 6 psi.
since the boost is directly related to the rpms and the ratio of rotations between the crank the supercharger pulley, your going to make 7 psi max because of how fast the pulley will spin at redline, and the bosch 102 bpv will release any boost over 7 psi.
you would make less boost if your belt started slipping, or you had a vacuum leak.
Old Nov 13, 2007 | 04:49 PM
svrTc06's Avatar
ok, i just wanted to make sure that nothing was wrong...somthing that id have to take it to the dealer and have them check it out or whatever.
Thats kool though, well thanks for the help
Old Nov 14, 2007 | 01:05 AM
kikcaffine's Avatar
Funny story the other night when it was like 33 degrees out I made 9.8psi on my 9.5 pulley. It did it 2x. epic.
Old Nov 14, 2007 | 03:09 AM
zer0's Avatar
yes I can hit 8psi on the stock pulley on a nice cool night in 3rd gear... the S/C loves all the cold air it can get
Old Nov 14, 2007 | 03:11 AM
kikcaffine's Avatar
Yeah and I have an intake too so that may be partially the reason
Old Nov 14, 2007 | 04:06 AM
do you have the stock bpv? because i thought that once you get to 7 psi, the bosche 102 will release any excess boost over 7 psi.
Old Nov 14, 2007 | 04:09 AM
kikcaffine's Avatar
hell the stock bosche will release after 6 pounds
Old Nov 14, 2007 | 08:34 AM
06SuperWhite_SoCal_tC's Avatar
what you're describing is the function of a wastegate... BPV/BOV do not release boost pressure when they attain a certain ammount of boost. They only open due to vacum.
Old Nov 14, 2007 | 11:39 AM
Buck's Avatar
It sounds like the Bosch 102 tends to leak before even 7 pounds of boost though.
Old Nov 14, 2007 | 06:17 PM
Sleep3r's Avatar
i am one of those unlucky ones with the TRD goost gauge being a little off!
Old Nov 14, 2007 | 06:42 PM
kikcaffine's Avatar
Not when the diaphram folds under pressure and opens, thus releasing pressure.....
Old Nov 14, 2007 | 11:20 PM
BLUEMEANIE's Avatar
Team Hamster
My aem gauge peaks at 5 or 6 if I'm lucky. I think it hit 7 once or twice. It seems like it usually never reads over 2 maybe 3lbs at red line. But I tapped the line at a crappy spot and haven't had a chance to change it.
I'm also using the Forge 007 with the red spring
Old Nov 15, 2007 | 03:38 PM
kikcaffine's Avatar
^ wow. I would think you should be pinned rite at 7psi.
ColonelSanders85
Dec 9, 2020 09:44 AM
That_Kid_Ju
Jun 26, 2015 10:57 PM
SloTC1
Apr 2, 2015 07:11 PM
mvez
Scion tC 2G Aero & Exterior
Feb 4, 2015 01:15 AM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
