About oil pressure sensor connection...
Do you guys have your oil pressure sensor directly connected to your oil adapter on the bottom?? If so, how long has it been there connected?? any problems??
Or do you use an extended hose, then connect the sensor (to avoid direct heat)??
I asked cuz, it seems to get really hot down there, i think it damages my sensor and caused my gauge to not work properly (the stick is just on 0). I replaced the wires and tried a new gauge and still not working. Then i replaced a new sensor, it worked...but went back again to not working when i was driving in a hot sunny traffic.
anyways, this can be a heads up concerning your oil pressure.
Originally Posted by yamaha16bw
I have mine T'd off the stock oil pressure sender. No problems and its been there for about a 6 months
http://cgi.ebay.com/ebaymotors/ENGIN...temZ7998001713
I had one of those block adapters but I didnt like it. I would suggest to anyone with an oil pressure gauge to hook it up this way.
I got mine online but you can get a Brass one at autozone for just a couple of bucks. Its called a 1/8th NPT Female "T".
http://www.magnumforceracing.com/xrp...m_adapters.asp
What are the measurements for those pieces on your fitting? The adapter that turbonetics sent cracked and my car is out of comission until they can send me another. I know its BSP, but where can you find them, and what particular size is the t-fitting and adapter?
Originally Posted by zer0
Depends, Tnetics make you retap the thread on the head..correct? IDK what size they are at that point... but stock it should be 1/8th
my06tc
Jun 25, 2015 12:18 AM
kingofthecrate
Jan 21, 2015 09:28 PM
