aem wideband install
anybody have a write up on the wideband install for the zpi stage 0 turbo? just wondering cause i'm doing the install this weekend! thanks ins advance
- find a spot on the s-pipe taking in consideration of room for the sensor and how long down the exhaust in inches from the turbocharger (I forget off the top of my head but AEM recommends like 16-18in, not sure so refer to the tech book with the kit)
-Then remove the s-pipe, and take to a muffler shop, if you don't have the means in the garage (Cost about $10)
-Reinstall s-pipe, run wires for the sensor through the rubber grommet in the firewall on the driver's side.
-Find a good ignition on 12v source. I tapped into the aux power outlet inside the arm rest. Only on when the ignition is on. Then run a chassis ground
hata
Sep 8, 2015 01:58 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
