aftermarket FPR on returnLESS system?
Old Dec 2, 2009 | 03:08 PM
cburglb34's Avatar
Default aftermarket FPR on returnLESS system?
im just wondering if anyone has put a fuel pressure regulator on our cars without a return fuel system..
if so a few questions i have..
what is the stock pressure?
and what did u use to keep the one inside our tank open?
Old Dec 2, 2009 | 03:17 PM
cburglb34's Avatar
oh yea and how much can we raise it with tthe stock fuel pump
Old Dec 2, 2009 | 03:45 PM
DezodDon's Avatar
Bad idea. It would just cause the regulator to open in the sending unit and bleed off additional pressure. If you want to control fuel pressure you need to run a return system.
Old Dec 2, 2009 | 04:17 PM
ElevationTC's Avatar
Nice sized rivet, a aftermarket FPR, some -6 line and a couple fittings and tools!
easy task!
Old Dec 2, 2009 | 05:54 PM
gingles's Avatar
^^or you can just completely remove the stock fpr like i did
Old Dec 2, 2009 | 06:32 PM
SoFloTC's Avatar
easy task!
dayumm dawgggg that mtuned christmas tree looks like it needs a re-tune!
Old Dec 20, 2009 | 08:47 PM
johnhawkins's Avatar
That is the OEM FPR correct???? Can you just weld it shut? How did you completely remove it? Can you remove it and just plug the hole?
Old Dec 20, 2009 | 09:44 PM
m6ar2cel6oTC's Avatar
Mike come do my return setup!
Old Dec 20, 2009 | 10:09 PM
trd07tc's Avatar
just do it right
carid
Mar 30, 2015 07:08 AM
carid
Feb 9, 2015 01:49 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
eric_m
79
Mar 17, 2013 12:21 AM
