ALL INCLUSIVE GUIDE for "What NOT to do" FI version
Old Apr 7, 2010 | 04:07 PM
  #61
ecko04's Avatar
Here's some good advice and probably obvious.....
Take your Scion to PTuning for a one stop shop F/I solution if you are not capable of this level of modification. Be honest with yourself. If you can't do it, take it to a competent shop.
/thread....lol
True story
Old Apr 7, 2010 | 07:08 PM
  #62
tC_litigator's Avatar
Originally Posted by ecko04
First and foremost, Fred would not even start his car with the TRD flash.
You are doing EVERYTHING wrong. The TRD flash for the ECU is certifiably not made for the purposes of boosting a car beyond that of the TRD supercharger which is fails to do adequately.
You mentioned why more people haven't gone your route in your thread, and that's the reason why, it's a recipe for utter failure. The TRD map does not adequately adjust timing, fuel, etc. for 440cc injectors. In fact, the TRD flash was made for 410cc injectors, stock injectors are 330cc.
The stock ECU does have conservative relearning, it is NOT made to adjust to the needs of a boosted car, that's why there are management systems, if it were good enough alone there would be no market for other management systems for the tC.
It is clear that your personal experience mimics that of a guy who stayed at a Holiday Inn Express last night and miraculously wakes up and knows everything about forced induction.
Your car, your setup, this thread wasn't created for you, it is made for YOU and others like you who tend to do things the WRONG way from start to finish, to start again when the motor blows but carry on.
Well my brother, lets break your analysis and uncover your misunderstandings. "First and foremost" its imperative that you read what is written before you comment. "My people perish because of lack of knowledge." You, my friend, appear to have much knowledge WRT the tC, something i cannot by any means discredit. HOWEVER, its imperative that you read what i wrote. I don't mind that people bash what they want/believe that i say or said.
1) I never said that Fred would start his car with the TRD reflash....read my aforementioned posting.
2) I never said this was the perfect setup BY ANY MEANS....read my aforementioned posting
3) I never said that i used "the stock ecu".... read my aforementioned posting.
4) If you actually hadpersonal experience with number to prove what you're saying, i'd have much more respect for these specific "observations" you have
5) For the LAST flippin time, i said i'm NOT driving the car like this. It was driven a few times (5-7), and notice that AFR's are consistent and (as we all have stated b4) begin to lean out toward the top of the rpm band. The tC is currently sitting in my security gate waiting to be carted off for more surgery
6) Engine check light is on, and ONLY indicates an O2 sensor malfunction because there is no secondary cat.
Ladies and gentlemen, please, all i ask is that you READ what is written before you jump to conclusions. Sheesh .
Finally, for those of you who WOULD BE crazy enough to do what i did, research before you do. You do NOT want to blow up your motor. Proper Preparation Prevents Poor Performance.
Old Apr 7, 2010 | 07:12 PM
  #63
Agreed my friend, PTuning has some of the most progressive engineering put into they're products. Who knows with what i'm getting from uncle sam, i may just do that. Is elevations built motor still for sale?? Maybe i'll just have an all out beast
Old Apr 7, 2010 | 08:02 PM
  #64
ScionFred's Avatar
I'm not sure if you're referring to me but I seriously considered trying the TRD ECU flash for a T04E 50 trim at 6psi. I decided against it mainly because the flash is irreversible and I've heard that it pulls too much timing. What the TRD flash would do well is injector size compensation. The TRD flash will have no problem trimming 440cc. I ran 6psi for about 6 months with 440cc injectors, no flash and no piggyback. The ECU did a remarkable job of adapting to the injectors (440cc is the upper limit, IMO). It took about 100 miles to learn them, after which the car ran great. Better than a piggy with a mediocre tune. It never stalled, never stumbled, never knocked and OL AFRs were between 10.5 and 11.5:1. The biggest problems were a recurring P0101 caused by the increased air intake and the 100 miles it took the ecu to re-learn trims if the battery was disconnected. It didn't run too well for the first 100 miles while the ECU was learning the 25% larger injectors. After the initial 100 miles the only CEL I ever had was the P0101 for MAF out of range.
I agree with Tc_litigator that it is possible to tune a low-boost turbo engine without a piggyback or standalone. I wouldn't recommend it only because of the difficulty finding the right combination and the potential risk. However, IMHO it can be done and done well. You could use a MAF signal clamp or basic MAF signal modifier, a return fuel system with a 1:1 or RR FPR, a carefully tuned MAF pipe, a boost activated O2 sensor signal modifier (URD, Flyin' Miata) and WMI would easily negate any need to retard ign timing at only 6psi.
Basically I went with the FIC mainly to eliminate the P0101 without having to fabricate a new intake/MAF pipe and to pull timing so I wouldn't need WMI. I was also concerned that reducing/clamping the MAF signal to avoid the P0101 would lean out my OL AFRs forcing me to compensate with progressively higher fuel pressure, requiring a return system and FPR. The FIC and harness probably cost about the same as the mods necessary to tune without them so for 99.9%, a piggyback is the best choice, but not necessarily the only choice. JMO.
Oh yeah, I agree 100% with DezodDon. If I had known how little I knew when I embarked on my boost project, I would have paid a professional shop to do it instead.
Anyway, I suppose that boosting without a piggy or EMS does belong on this list even if it can be done.
Old Apr 7, 2010 | 08:06 PM
  #65
ecko04's Avatar
You never said it, you're right, I think you missed the context that I was using it in.
It is far from perfect, it's altogether wrong.
It's already understood you're using a STOCK ECU w/ TRD FLASH. You are using the TRD flash with no piggyback or other management system. There is no such thing as a TRD ECU, it's a STOCK ECU with FLASH. Once flashed it cannot go back to "stock".
Funny, you think I don't have personal experience...you would be entirely wrong in your "observation".
Highlighted text contradicts highlighted text, further indication that you're doing it wrong, which is the basis of this thread.
Which code is it showing? Is it one that would cause the car to go into open loop in which case your AFR "consistency" that you already misrepresent would be incorrect.
No one is jumping to conclusions, we're stating the obvious based on what you already have said.
Lack of proper preparation LEADS to poor performance.
Old Apr 7, 2010 | 08:13 PM
  #66
ecko04's Avatar
I'm going to cut you off here because I think you missed the point I was making. The idea isn't that it can't be done, it most certainly can, i.e. ZPI Stage 0, with a smaller turbo.
The point here is that it shouldn't be done, you stated your reasons why you opted not to do it, tC_litigator is going well beyond the bounds of what's actually "safe" .63 A/R exhaust .70 A/R compressor is not equivalent to T04E 50 trim.
This is the part where it just gets iffy, the idea here is to provide general rules of thumb without going into the vast details and differences between turbos, housing sizes, CFM, etc.
The general rule of thumb here and I think everyone agrees, is simple, don't boost without a proper tune, utilizing the TRD flashed ECU is not a proper tune and far from ideal.
Old Apr 7, 2010 | 08:29 PM
  #67
Thank you sir, i respect that. Honestly, I just thought it would be interesting to see additional results since so many people are against it w/o first had experience. I will also stop there. There's no need to disagree about a point we seem to agree with.
I digress...
Old Apr 7, 2010 | 09:17 PM
  #68
deathbyc4's Avatar
A Scion is not exempt from Murphy's Law.
Old Apr 7, 2010 | 09:37 PM
  #69
ScionFred's Avatar
My results were with a .63A/R turbine housing, stage 3 wheel, .60A/R compressor housing, 3" major dia., 2.122" inducer (50 trim) wheel. But you're right, many other factors are part of the overall equation.
All in all, we all seem to agree that boosting w/o at least a piggyhack is a big "what not to do" for the vast majority of peeps. I'm out...
Old Apr 7, 2010 | 09:42 PM
  #70
Slikk's Avatar
Music City Scions
Originally Posted by crush02342002
Dont assume your engine can handle boost, atleast do a comp test to have a better idea.
This is didn't know. I figured as long as i stay under 11LBS on a good tune i would be ok.
Old Apr 7, 2010 | 09:49 PM
  #71
CarbonXe's Avatar
My results were with a .63A/R turbine housing, stage 3 wheel, .63A/R compressor housing, 3" major dia., 2.122" inducer (50 trim) wheel. But you're right, many other factors are part of the overall equation.
ZOMG!
Old Apr 7, 2010 | 11:15 PM
  #72
crush02342002's Avatar
dont buy used con rods, I dont care what the seller "thinks" or says!!!!!!!!!!!
  #73
you know who you are
Old Apr 7, 2010 | 11:20 PM
  #74
ScionFred's Avatar
Originally Posted by CarbonXe
ZOMG!
Old Apr 7, 2010 | 11:33 PM
  #75
Thorium06's Avatar
uh oh, sounds like an epic story, what happened?
Old Apr 7, 2010 | 11:49 PM
  #76
cburglb34's Avatar
ZOMG!
hes trying to make fun of u saying stage 3 because staged turbos are usually china chargers....
but since he is not a very bright kid, he had no idea u were running a precision..
Old Apr 7, 2010 | 11:52 PM
  #77
nothing except one of my customers recently was screwed over by another memeber on here. I told him i didnt think it was a good idea but he did it anyways under the great advice of a certain someone. he got the con rods almost a month or two after he payed for em and got damaged con rods (this is something you cant blame ups on...lol), they didnt look right to me and the machine shop confirmed that today. Ill leave it at that.
Old Apr 8, 2010 | 12:08 AM
  #78
Thorium06's Avatar
wow thats sucks, sorry to hear that
Old Apr 8, 2010 | 12:12 AM
  #79
brett561tc's Avatar
what kind of rods?
Old Apr 8, 2010 | 12:16 AM
  #80
Ill let my customer explain the rest if he wishes.
