Answer to the "How do I clock my turbo?" Question
How do I clock a turbo?
What is clocking a turbo?
Two common questions one easy answer!
I remember the first time I heard the term I had no idea what that meant so to help out anybody who has questions I put together a short video that describes how to do the clocking and what that means.
Here is the video "How to clock a turbocharger"
Originally Posted by coryjames
any one that knows how to turn a wrench should need this vid
^^ agreed.. and know how to troubleshoot.. i should have installed my turbo kit myself, the guy clocked the turbo and used an impact wrench to tighten it, now i couldnt loosen the bolts
Ohh thank god, I kept seeing this post and I thought it was someone asking about timing and clocking their turbo.
Very nice though :-) I wish I would have gone turbo'd instead of S/C'd. Hindsight is always 20/20 though
Nice vid btw. People should keep in mind that not all turbos use the same mechanisms to be able to clock them. The mitsu turbos are held together with a snap ring that you squeeze together using angled needle nose pliers. You have to squeeze and then you can clock. The center housing (oil feed/return) is held together with a single screw in a C clamp that holds the compressor and center housing together.
bootlgr
Jan 26, 2016 01:22 AM
