Anyone know How to Wire this to a tC?
Old Oct 26, 2008 | 06:36 AM
  #201
olaHalo's Avatar
wait so as im reading there isnt an "up to date" diy on this?
instead of finding all those wirings i can just tap them on the ecu harness???
Old Oct 26, 2008 | 11:59 AM
  #202
jon_n2mb's Avatar
Ah, when you do your install tomorrow, do you want to try installing it the alternate way and taking pictures for us to update our instructions?
By alternate way, I mean tapping the GREEN, BLUE and YELLOW wires at the ECU instead of where we have shown.
The tC installation instructions are here:
http://www.npcompleteperformance.com...oninstructions
The ECU pin numbers are in this set of instructions in the tables:
http://www.npcompleteperformance.com...structions.pdf
Lastly, I would also recommend changing the tap at the fuse box. Instead of splicing into the black wire that goes into the IG2 relay, can you tap into the pink or red wire that comes out of the IG2 relay? That way, the WOT Box will turn off when you power off the car. If you wire it as shown we have realized that the WOT Box stays powered up all the time.
When you do the splice, cut the red or pink wire that comes out of the IG2 relay. I believe it will be terminal #3 on that relay. Connect the RED side of the WOT Box red/ black pair towards the output of the relay and the BLACK side of the WOT Box red / black pair away from the relay.
Can you also take a picture of that splice? We will use it to update our directions.
Thanks
Old Oct 26, 2008 | 12:00 PM
  #203
jon_n2mb's Avatar
If you have any questions during the install, please email support@n2mb.com. I will be away from the forums today, but I can answer email.
Old Oct 26, 2008 | 01:50 PM
  #204
olaHalo's Avatar
will try thanks for the info
Old Nov 2, 2008 | 01:17 AM
  #205
Prophecy2k4's Avatar
If these aren't back ordered and there are no ill effects so far, I'll take one. Can I just order it through the website?
Old Nov 2, 2008 | 11:32 AM
  #206
jon_n2mb's Avatar
250 in stock right now. :-)
You can order through the introductory group buy ($10 off) link by clicking here:
http://www.n2mb.com/wotboxgroupbuy
Thanks!
Old Nov 9, 2008 | 11:30 PM
  #207
darkscion's Avatar
bump,any new info??
Old Nov 9, 2008 | 11:33 PM
  #208
jon_n2mb's Avatar
Originally Posted by darkscion
bump,any new info??
Hmm... Like what? Works great. Lots of fun.
I'm working on a major new software release that will add Windows software for configuring options and a bunch of new features... You will be able to download it when it is ready...
Old Nov 10, 2008 | 03:05 PM
  #209
darkscion's Avatar
have you updated the install info so that we can wire it to the ecu,instead of running the wires to the engine bay? i thought you guys were workin on that.
Old Nov 10, 2008 | 04:06 PM
  #210
jon_n2mb's Avatar
Yes, we are waiting for someone to do the installation at the ECU and send us the pictures. The pin numbers and wire colors at the ECU are available here:
Old Nov 12, 2008 | 12:26 AM
  #211
olaHalo's Avatar
i installed it similar to the DIY on the site jon
i placed the box itself near the fuses under the steering wheel. Instead of have all the wires go under the center console, they just go right up to the other wires.
great product
Old Nov 24, 2008 | 12:09 AM
  #212
darkscion's Avatar
well i just got mine intstalled and its not working properly,it seems to fuction ok as far as full throttle shift,but the launch control will not work at all.and ive checked the wiring about 10 times now,even checked the yellow wire for continuity and its good.has anyone else had this issue??
focal06
Scion tC 1G ICE & Interior
Apr 25, 2011 09:04 PM
stl_tc_king
Jun 6, 2007 01:14 AM
sciontc_06
10
May 5, 2007 07:04 AM
gicode0823
Feb 16, 2007 06:24 PM
SF2K4
Mar 6, 2006 06:18 AM
