Back from ptuning and everything went great!!!!!!!!
Old Aug 22, 2009 | 07:22 PM
Steventc07's Avatar
Originally Posted by SLEEPER24
well im on the trd clutch right now but am looking to upgrade in a while, im running my injen aback exhaust with 2.5 inch spipe and mid pipe from true benz.com, which by the way are great. i would like to see if i could get it up to around 280 or better ill be happy with that, the gut that i bought it from was running it with the stock 7lb spring in the waste gate and he said that he was pushing 265, so if that is true then i should get there with no problems.
Originally Posted by Cwatz5219
Current mods are:
ZPI stage 1 kit with 9psi spring
Emanage ultimate with pressure sensor
TRD performance clutch
2.5 turbo back exhaust
Car only boosts to 7psi which i dont understand why but we're looking to get it tuned at 10-11psi
You're not going to see 280whp on Ptuning's dyno just to let you know. I made 249whp on their dyno (dyno dynamics) with a Dezod S1 kit, 2.5" Exhaust, and a Agency Power lightweight pulley. This does translate into ~280whp on a dynojet tho, and I would think you will be somewhere close to that. Despite your smaller turbo, your open WG, catless DP, and more boost should put you somewhere around there
Old Aug 22, 2009 | 07:38 PM
Cwatz5219's Avatar
^^^ The wastegate was recirculated into the dp by the previous owner
Old Aug 22, 2009 | 08:06 PM
SLEEPER24's Avatar
damn you just shot me down, ooooooo well i guess that it is better to no now then get dissapointed later
Old Aug 22, 2009 | 08:24 PM
Steventc07's Avatar
i'm not trying to shoot you down. just telling you reality. And setting record numbers isnt everything, the car will still be FAST lol and Toan knows his shiz so it should last
Old Aug 22, 2009 | 08:38 PM
SLEEPER24's Avatar
yeah i no i was just playing but thanks for the info i really appreciate it
Old Aug 22, 2009 | 08:43 PM
Steventc07's Avatar
np man. Good luck, hope everything goes smoothly!
Old Aug 22, 2009 | 08:46 PM
Cwatz5219's Avatar
Does anyone know what the 16g turbo maxes out at as far as HP or PSI???
Old Aug 22, 2009 | 09:03 PM
SLEEPER24's Avatar
thanks man
Old Aug 26, 2009 | 03:21 PM
ecko04's Avatar
It took 11.6PSI and a 3 inch exhaust on a TT kit to crack 280whp on PTUNING's 2400 AWD dyno dynamics.
I'm at 9.5psi, 2.5" catback (magnaflow), vibrant resonator, T3/T4 turbo, lightweight crank, alternator and wp pulleys, upgraded cc stage 4, recirculated dump, upgraded walbro 255lph fuel pump and didn't crack 260whp...(258whp).
If I upgrade the exhaust which i'm not going to do and get rid of the resonator which I plan on doing i'll gain much more power but i'm happy where I am now. I'll loose the resonator now that I don't have the header and won't have to worry about horrid rasp.
Old Aug 26, 2009 | 03:30 PM
Cwatz5219's Avatar
Yeah Toan was telling us about your numbers. He said you produced some pretty decent numbers but like you said with a 3" exhaust he could've squeezed out a little more.
Our trip didn't turn out so well. He started off with a baseline pull to see where my boys car was at first before he started tuning and he produced 224whp/206wtq. After trying to install his MBC controller he noticed that the car would spike to 9psi then drop all the way down to 3psi. After trying out 3 different controllers he realized that there was something wrong with our wastegate. So unfortuantely after a 5hr drive we find out that we have to replace the wastegate, which he didn't have in stock, then come back. Other than that Toan was great and the customer service there is unmatched. We should be heading back there by next month or two depending on if we can find a reasonably priced Tial wastegate.
Old Aug 26, 2009 | 03:40 PM
ecko04's Avatar
What size WG? 38mm?
Old Aug 26, 2009 | 03:48 PM
ecko04's Avatar
Toan said there was much more power left to be made but I had a lot of restriction. Even the way the magnaflow muffler is made causes restriction. If I get a straight through 2.5" setup then I will see increases but most likely i'll just get the resonator removed and settle with that.
Toan said my setup was really quiet, which I like, i'm a fan of the sleeper look and sound.
I don't think i'll be going 3" I want the car in a position where it is easy to revert back to stock and have no issues, I think i'll loose too much pressure with a 3" exhaust if I needed to do that. With the turbo pressure takes a back seat but NA it matters.
Old Aug 26, 2009 | 04:00 PM
Cwatz5219's Avatar
Originally Posted by ecko04
What size WG? 38mm?
Yeah 38mm
Btw thanks for the friend request
Old Aug 26, 2009 | 04:06 PM
Cwatz5219's Avatar
Yeah thats what he said. You have one of the quietest setups he's ever heard. unfortunately for me and my setup he said i have to go with no less than a 3" exhaust from the turbo back so sleeper for me is def out the picture. lol
For us our issue is something that he's never seen before but after trying so many different things he narrowed it down to the wastegate. Hey said the minute we change the wastegate we should feel an instant difference.
Old Aug 26, 2009 | 04:07 PM
ecko04's Avatar
Yeah 38mm
I have a 38mm here if you guys need it.
I bought it used but I never used it. I think I have a brand new gasket for it too that I bought from Dezod.
Shoot me an address and I can get it to UPS when I go to send off these AEM gauges.
It is a T'netics 38mm but it is essentially the same as my TiAL that I have on my car, the only difference is the name on it.
Old Aug 26, 2009 | 04:09 PM
Cwatz5219's Avatar
Really??? How much???
Old Aug 26, 2009 | 04:15 PM
ecko04's Avatar
How much? The cost of shipping.
Old Aug 26, 2009 | 04:20 PM
Cwatz5219's Avatar
Wow. Curtis you are the man. Here's the address. I will send payment out asap.
Info Pm'd
Old Aug 26, 2009 | 04:21 PM
rosedaleny806's Avatar
^ nice! helping out a brother in need is awesome
Old Aug 26, 2009 | 04:28 PM
ecko04's Avatar
I'll get it out no later than Friday. I have to find it, I know I have it since I packed it, I just moved so I have boxes everywhere.
