Belt Slip
Old Sep 7, 2006 | 02:45 PM
dachmo's Avatar
Default Belt Slip
Has anyone had a problem with the belt slipping with the NST pully?
I have the K070890 belt and it sqeals when I start up the car. I noticed a lot of black belt dust by the tensioner pully, but everything looks like it is on correctly.
Any help would be appreciated.
Thanks
- Dante
Old Sep 7, 2006 | 02:52 PM
web's Avatar
web
I don't have that pulley, I have the Agency Power crank pulley and I'm good. How many miles are on it? Is your tensioner loose? Go to AutoZone and get a spray called "Belt Squeal" or something like that. Spray it on the pulley while it's running and it should help the belt grip a bit more.
Good luck.
Old Sep 7, 2006 | 02:55 PM
IceNine's Avatar
I have a 7PK2260 you can buy off me if you want to give it a shot ($20 will cover it, and i think you're pretty close to me). I was going to use it, but it turned out the 2250 fit with my smaller alternator pulley.
The 2260 is supposed to be perfect for what you're doing.
Old Sep 9, 2006 | 07:56 AM
06SuperWhite_SoCal_tC's Avatar
I have the 2265, and not even a hind of slippage from that even. No problems here...
Old Sep 9, 2006 | 11:46 AM
IceNine's Avatar
I had the 2265 until I added the 20% Alternator overdrive pulley. Then it just squeaked and slipped and was generally crap. I dropped to a 2250.
Old Sep 9, 2006 | 03:17 PM
dachmo's Avatar
Well.... I noticed that on the package K070890, regardless of the part number, the belt size is 89.75 inches and not 89 inches (It's a gates belt made for NAPA). The metric size for that is about 2279mm. So the belt I have on there is almost 2cm too long. I'm going to get a 2260 Dayco Poly Cog (just like a gatorback) and see how that works.
Wish me luck.
- Dante
Old Sep 9, 2006 | 04:08 PM
IceNine's Avatar
hehe I have a Dayco 2260 right here if you need it. $20 and it's yours. I'll even put it on for ya if you need.
Edit: Scratch that. Bring over a 12 pack of something decent and you can have it
WRX1316_TcVicent
Jul 22, 2021 06:06 PM
olyellr
Sep 28, 2015 10:32 PM
Ksn
Sep 21, 2015 06:21 PM
bmxScion
Jul 23, 2015 12:07 AM
