Benefits of return fuel system
I am wondering what are the benefits of doing a return fuel system in our cars. I have seen a handful of people do this, soundperformance for one. Why is this beneficial? Is this a way to get more fuel using smaller injectors by installing a fuel pressure regulator?
So in an essence if you were to want like a lil over 350hp normally people step up to 700cc injectors. But with a return system you could actually get over 350 on 550cc injectors safely..? Without too high of a duty cycle
im not and expert, but my assumption is that when you uprage a fuel pump and have the ability to regulate the fuel pressure with a return system it will allow you to get a better spray pattern when going with large injectors. Especially at idle when a large injector opens it may not have enough pressure behind it to have a nice spray patteren which can cause a rough idle. Also a return system will keep the fuel cooler as it recirculates.
Guest
Posts: n/a
https://www.scionlife.com/forums/vie...return#3183589
MrC
interesting. make sure ya click the link up a few posts, definately the benifits are explained well.
although the dissapation of heat is a small thing, I see it like this:
the fuel rail gets heak soaked from the radiant heat of the engine, it must dissipate somewhere. Fuel is almost as conductive as water I imagine so it is dissipated to the fuel entering the rail... and with a returnless system 100% of that fuel gets injected. With a return system there is an actual flow occuringf through the rail although not high volume it still carries a certain amount of that heat soaked fuel in the rail back to the fuel tank where it dissipates heat. So in theory it would keep the fuel cooler in the rail. Now at WOT a large amount of that fuel isnt even returned odviously because it is flowing through the injectors.
carid
Mar 30, 2015 07:08 AM
carid
Feb 12, 2015 11:54 AM
spawnconnery
Dec 18, 2014 08:38 PM
