Better turbo EVO III GT 16G or T3-T4 E-50 Turbonetics
Originally Posted by paul_dezod
Originally Posted by retrodrive
I am looking at it this way. T3/T4 is a slower spooling turbo then 16G but it will produce a little more power if you max both out (because of their size). BB option would make T3/T4 spool a little better then it does without BB but then reliability goes down. I like regular turbos because they are more dependible and the difference in spool between BB and regular turbo is not large enough to sacrafice reliability. 2.4 TC engine will spool the 16g faster then T3/T4 so you would get your power sooner and the lag is virtually non existent. If you max out both turbos you would end up with a blown up engine anyway so I would go for smaller one.
In actuality, I feel the tC is really pushing that 16G too hard. In some cases on some lower boost, it is close to the choke point. From some quick and dirty calculations, with a pressure of 10 PSI (1.68 Pressure Ratio), that turbo at 4000-6000 RPMS just continues to plummit from a peak efficiency of 71% at peak TQ and falls off to a bit over 60% by redline. The fall off in efficiency means decent temped compressed air @ peak efficiency then as it falls (RPMS increase here), to really hot condensed air making the intercooler work twice as hard to cool that air. The intercooler only has a limited amount of cooling capacity (most are 75%), this means that your intake temps just got a bit hotter, which in turn means you are getting less power.
Also, the 16G has an Inducer of 1.903" & Exducer of 2.675", turbine exducer of 1.935" & major of 2.205". This turbo with these specs reaches your peak CFM at 25 PSI. What does this mean? It only puts out about 27lbs/min (really rough calculations). Yes out put will increase as PSI increases, but how many people on here are going boost past 15 let alone 25? Probably 5-10%.
I feel the generalization of T3/T4s being too laggy comes from a scenario like the T3/T04E 50 on the tC. The TQ curve is not really that flat, and notice how 'hill like' it is, a mountain if I may:
A flat curve means more area under the curve, which means more useable power.
Note how flat ours is. Now just to make a bit of a comparison and make them seem more alike, I will truncate the T-netics graph from 3700RPMS or so on....
So all in all, our turbo is a T3/T4 and spools failry quickly due to several attributes in the system including turbine A/R. Our peak TQ is made at 3800-4000 RPMS, which is the same as almost any 16G (which is also supposed to a fast spooling smaller turbo) if you want to judge a turbo's merit by when it begins to make boost. That is hardly a good measure.
Cost, build, power goals (I want 5xx HP), power distribution (I want some mid-range and top end vs low to mid-range), warranty info and how well it works with what your doing.....
Originally Posted by MIAPLAYA
You need to remember that tuning plays into this tq curve a lot too. The drop in tq on this graph is due primarily to a reduction timing at the top end to keep things very safe... This is pretty typical of out of box Turbonetics kits. They pull a LOT of timing top end to keep the AFR safe with 91 octane we have in Cali at the top end...
I'm not sayng he pulled TOO much timing. Just that he HAD to pull more then you due to the gas we have here. The 91 here is barely even that. EGts are right in line where they should be. But to keep an 11:1 he had to pull more then you did. Believe me in Jhames 20 years as a Mechanical Engineer designing, building, and tuning turbo kits and race cars he's pretty well versed in the art of fine tuning and would not put something out that was unsafe.
Scionxa180
09-24-2015 03:51 AM
Subaru86
07-31-2015 04:00 AM
