built motor but misfireing..updated with tune still same
Old Oct 23, 2009 | 12:53 AM
garynkim's Avatar
Default built motor but misfireing..updated with tune still same
hey guys want to know what kind of spark plug is every1 is using ngk or denso.. im using denso ik24 right now still have not gotten it tune yet after the full built and its misfiring like mad.. not sure if its the new spark plugs. bc fi stage 2 cams.. or just the tune.. a/f r. reads 14.4-16.1 at idle and vacuum is all over the place from 18-10hg and stalls
Old Oct 23, 2009 | 02:14 AM
gingles's Avatar
the plugs i use are the ngk one step colder right now...bkr7eix, id check your coil packs....is it only misfiring at idle? also see if your plugs are fouled...need a tad more info
Old Oct 23, 2009 | 02:45 AM
crush02342002's Avatar
what engine managment? have you checked for leaks cause your vac should be between 19-20 at idle.
Old Oct 23, 2009 | 02:46 AM
plug gap?
Old Oct 23, 2009 | 03:27 AM
m6ar2cel6oTC's Avatar
Any cel? How's it drive? More info!!
Old Oct 23, 2009 | 03:31 AM
yamaha16bw's Avatar
IK24's here. I'm willing to bet you just need a tune. I did the Stage 2 NA BC cams and mine sounded like crap and didnt idle well till it was tuned up. I'd bet the FI cams are worse.
Old Oct 23, 2009 | 04:09 AM
why did you go for n/a cams instead of FI?
Old Oct 23, 2009 | 04:29 AM
garynkim's Avatar
im running on the greddy eman. ult. was tune for 12psi,rippmods cams,mmw header,draxas exhaust, cai, meth and 570s cc injectors,new set up after rebuilt was, 3 angle valve job with 1mm oversize bc valve,bc stage fi cams with spring kit,cometic .051headgasket, world racing intake mani,14psi pulley, 88.5 9-1 wiseco piston and k1 rods with the internal balance shaft removed. i checked all the vacuum lines,check the coils, when i down shift from 3rd to 2nd sometimes i stall, and cel is system too lean, random misfire and every cyl.. im not sure if every1 here had this problem with there rebuilt motor.. and last thing the spark plug is just standard gap i guess .032 also far for break in i got about 90miles haha...
Old Oct 23, 2009 | 04:35 AM
gingles's Avatar
wow....nice sc build....i wanna see dyno's and updates
Old Oct 23, 2009 | 04:51 AM
elcapetan's Avatar
I wanna see a dyno too
Old Oct 23, 2009 | 04:53 AM
running to lean!!! you need a base map!!! you have a intake manifold!!!! you need a tune plain and simple!
Old Oct 23, 2009 | 05:03 AM
gingles's Avatar
wait.....so its not even tuned yet? no basemap?
Old Oct 23, 2009 | 05:16 AM
Ace83's Avatar
Ronin Scion
you have a crazy idle? like jumping afrs? sometimes you need a richer idle afrs with aggressive cams to make idle stable.. is your idle rpm surging? does it stall at times?
Old Oct 23, 2009 | 05:36 AM
someone correct me if im wrong but i remember the bc cams having issues with the cam sensor...something to do with the sensor comeing into contact with the pins on the cam. any cam codes? do you know what your fuel trims are?
Old Oct 23, 2009 | 05:42 AM
gingles's Avatar
yea ive heard you have to grind something down
Old Oct 23, 2009 | 02:35 PM
yamaha16bw's Avatar
NO you dont have to gring anything.....the Cam sensor pickups have a bigger gap then the stockers. Its as simple as tapping them out a bit to meet stock spec. Then you wont have a problem.
I went for the NA's cause I didnt do the rest of the head and the NA's dont call for any other mods.
Old Oct 23, 2009 | 04:09 PM
i thoguht the stage 1's didnt call for any mods either.
Old Oct 23, 2009 | 08:35 PM
garynkim's Avatar
my idle rpm is surging and it does stall at times..
Old Oct 23, 2009 | 08:38 PM
garynkim's Avatar
i guess not really haha.. i mean i have base map from what it used to be.. but not with the new set up.. yea.. i think i did almost everything i can with the sc i will deff.. show some dyno #s when its done.. i just hope i have enough exhaust flow.. on the 2.5in exhaust.. hehe.. right now im have my date set up with rippmods on coming up week tuesday.. will let every1 know how itll be.
Old Oct 23, 2009 | 10:08 PM
2.5 will be good for that s/c good luck breaking 300whp!!
