built motor but misfireing..updated with tune still same
ok guys i went to different tuner.. somewhere local and after tuning the car it made 207whp and 193tq runnin lean on top end.. the car still misfires and still runs like crap the tuner couldnt change the fuel settings at 5k rpm to redline. from 5k rpm it dips down to 10.5 then by 6k goes to 12.9 and still stalls at idle from time to time boost gauge was reading 10psi.. any advise?
what is your gap on your plugs? and thats whole dumping in the fuel might be that your knocking and your ECU is dumping alot of fuel. and you should be making alot more power then 207whp. when i was s/c i made 270 on 10.5 psi with meth and you have intake mani?
want to know how amp i knocking tho?? wouldnt the tuner know?? kinda lost there is it because i remove the internal balance shaft?
i got there 11am went on the dyno around 1130 spent about 2-3 hours on the dyno then 2-3hours then on the phone with greddy explain to them what is going on.. at the end nothing was really done and charged 733.35..
you wont always hear your motor knocking. a slight small knock that the sensor senses and it will dump fuel and take timing off. and if the tuner didnt connect anything to check in like hat obdII reader then you wont know if its knocking or not. the greddy ultimate with the PNP harness i dont think it will tell you knock. i dont think it was wired with it from what i seen somewhere. asl DEZOD if there harness was wired up to sense knock on the ultimate.
standard for the 2az-fe is .44 gap. i think the iridium come in .34 or .32 gap. you might wanna check it out. i have my plugs gapped at .32.
