CarbonXe is boosted. 287.2/272
Originally Posted by crush02342002
Originally Posted by java09
247whp 265wtq!
bahahahahaa
bahahahahaa
It's pretty much already tuned. The only thing I can't do is the ignition map. When I'm at PTuning, I'm going to see if their tuner will take a look at it and give me some pointers, but other than that, I won't be taking it to any shop.
No, I'm leaving my O2 map. It works out nicely for Open/Closed loop and partial/WOT. I'm in closed loop while on throttle, and I have full control over the fuel map, and it switches to Open loop during fuel cut. Only problem is the CEL, which I don't mind because it hasn't had any affect on my AFRs, and I can just clear it with my ScanGauge.
yeah i was about to say that im getting a system to lean bank 1 code. oh btw would you have any imfo on p0171 cam sensor, i got that code too and i forget what the fix for that is.
Originally Posted by SVicksTC
Where is p-tuning located im in PA and im going for a new tune over my christmas break what are there prices like?
Anyway i wish the best of luck with the tune...
They're expensive, but you're sure to get a great tune. The only two reputable shops around me were RIPPMods and GodSpeed. I checked them out and managed to get their tunes...and I will NEVER be going to their shops. You're essentially paying $400 for a Dezod base map with some minor tweaks.
The only other shop I'd recommend for you, which is probably the same distance as PTuning, is Dezod up in Buffalo.
P2195 (Oxygen [A/F] Sensor Signal Stuck Lean [Bank 1, Sensor 1])
I haven't had the Cam code, but from what I understand, it's just a resistor between the Cam Mag+ and Cam Mag - lines in the harness (don't hold me to it, look into it more).
247whp 265wtq!
bahahahahaa
bahahahahaa
he will make good numbers guarenteed!
no, i finaly got someone to bring a laptop to work. but their computer couldnt load any of the drivers for some reason. so it was a no go, computer wouldnt connect to the fic. they are using vista so idk if that had anything to do with it.
Let's play a game. Who can guess my HP. I'll be taking it to PTuning this weekend to get it dyno'd. Setup is a 57 Trim .63 A/R, 12PSI, full 3" turbo back exhaust, open dump pipe, very conservative ignition tune (.75º pulled per PSI). I'll be running on a Dyno Dynamics AWD dyno, which is known to read much lower than a DynoJet. One guy over on NASOIC did a comparison and ran 275/232 on a DynoJet and 224/192 on a DynoDynamics.
http://forums.nasioc.com/forums/showthread.php?t=286440
So take your guesses :D. I'll have numbers and video of the pull this weekend.
