CarbonXe is boosted. 287.2/272
Old Nov 29, 2008 | 03:30 AM
  #1541
crush02342002's Avatar
system too lean bank 1 (p0171)
and i was getting p29** dont really remember the rest
Old Nov 29, 2008 | 03:36 AM
  #1542
I wonder if my maf is dirty and causing it to be such a biznatch. i looked up that code p0171 and it made that suggestion. kinda makes sense, i cleaned my filter recently and may have used a bit too much oil on the filter. idk but ill try that
Old Nov 29, 2008 | 03:39 AM
  #1543
CarbonXe's Avatar
Originally Posted by Ace83
yup sounds nice.. cant wait for my new exhaust..
jon, how loud is the ptuning exhaust? is it on the loud side like tsudo n1 or megan catback?
Not at all. On the highway, it has minimal drone and it's not really all that loud in general.
Old Nov 29, 2008 | 03:40 AM
  #1544
CarbonXe's Avatar
The system lean code is from the O2 map on my tune. It's always reading 1V, so it thinks it's always running lean. Then after so many cycles, it realizes that it's stuck at 1V, so it throws the P29**, which is O2 sensor stuck lean.
Old Nov 29, 2008 | 03:43 AM
  #1545
any idea why my fic keeps rejecting your tune
Old Nov 29, 2008 | 03:47 AM
  #1546
CarbonXe's Avatar
No idea, it might have to do with that CAM thing. I'm running the newest firmware and software on the newest F/IC unit, so it just might be something with agreement issues.
Old Nov 29, 2008 | 03:49 AM
  #1547
i think im using v3.04
  #1548
ippskidder's Avatar
1UP Crew
I got my boost controller to work!!!!!!!!!!!!!!!!!!!!!!!
12psi feels dammmmmm gooooooooddddddddddddd.
I'm gonna see if I can get a baseline run tomorrow.
After that, maybe some dyno time on wednesday, so I can clean up the light cruise, and high load areas.
AFR in boost (12psi) is 12-12.5 right now.
RAWR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 29, 2008 | 03:51 AM
  #1549
i just looked and it said v3.0 hmmmmmm
Old Nov 29, 2008 | 03:52 AM
  #1550
ficrelease08 is the program i got.......isnt that the most up to date?
Old Nov 29, 2008 | 03:53 AM
  #1551
sweet........yeah 12 feels reallllllllllllllllllllllllllllllllllllyyyyyyyyyyyyy gggggggggoooooooooooooooddddddddddddddddddddddd
Old Nov 29, 2008 | 03:59 AM
  #1552
ippskidder's Avatar
1UP Crew
I'm so happy. I might cry, muahhahahahhaha!
The problem wasn't even my apexi wiring I had done almost a year ago.
It was the freaking diaphragm in the wastegate. It was pinched, melted, and torn, horibblyyyyyyy.
I put in a used spare I had, in much better condition. Until my new one arrives next week. Tested the boost controller, and works like a charm.
Old Nov 29, 2008 | 04:06 AM
  #1553
congrats on getting that fixed
Old Nov 29, 2008 | 04:13 AM
  #1554
ippskidder's Avatar
1UP Crew
What kind of AFR are you guys running at 10-12psi of boost????
I think 12.5 might be a little to lean for my taste >.<
Opinions??
Old Nov 29, 2008 | 04:27 AM
  #1555
GReddy_tC's Avatar
Yea. I like to sit around 11.5-12 non higher.. But If you have meth injection I think 12.5afr is your friend..
Old Nov 29, 2008 | 04:41 AM
  #1556
B_Real45's Avatar
Opinions??
I'm having that issue on my Unichip tune. 10psi is close to 12.5. Too lean for my tastes.
Old Nov 29, 2008 | 04:42 AM
  #1557
ippskidder's Avatar
1UP Crew
I'll richen it up tomorrow then. If my bro lets me borrow his laptop, lol.
Hes been playing the WOW expansion day and night >.<
Hopefully i'll get alright number at the dyno, on a street tune ^^
Old Nov 29, 2008 | 02:04 PM
  #1558
Ace83's Avatar
Ronin Scion
Opinions??
thats on your built motor already and meth injectors? if so I would shoot for 12 afrs.. on stock motor with no meth stay at 11,5, youre in FL that can see 70s weather even on winter lol, those guys on cold weather are safer from detonation so they can go like low 12s on winter. And where is your ignition at from 8-12 psi?
you can go 12 on low rpms 2.5 to 3.5k then make it sweep to 11.5 afr
And get a laptop already and do unlimited street tuning!
Old Nov 29, 2008 | 02:05 PM
  #1559
ummmmm i think i found my problem......
doughnut gasket, go figure
when i installed i just sort of riged the stock one to work which did fine until i turned up the boost and in turn makes the engine rock back and forth even harder. so sometimes it would seal while other times it wouldnt. I got a new 2.5" gasket and coated it with copper hightemp rtv. I hope this fixes it
Old Nov 29, 2008 | 02:13 PM
  #1560
Ace83's Avatar
Ronin Scion
there ya go.. but did you have problems with your FIC before the resistor mod? you mentioned you have the latest FIC so you prolly dont need one
