CarbonXe is boosted. 287.2/272
Originally Posted by blown_xa
Originally Posted by CarbonXe
Let's play a game. Who can guess my HP. I'll be taking it to PTuning this weekend to get it dyno'd. Setup is a 57 Trim .63 A/R, 12PSI, full 3" turbo back exhaust, open dump pipe, very conservative ignition tune (.75º pulled per PSI). I'll be running on a Dyno Dynamics AWD dyno, which is known to read much lower than a DynoJet. One guy over on NASOIC did a comparison and ran 275/232 on a DynoJet and 224/192 on a DynoDynamics.
http://forums.nasioc.com/forums/showthread.php?t=286440
So take your guesses :D. I'll have numbers and video of the pull this weekend.
I don't want to expect too much, so I'm still going to say 250-260, lol.
Well good bye tires. They broke loose in 4th on the way to work...I'm just glad I don't have any wheel hop, when these things start spinning, they don't even try to grab again lol.
They won't do any tuning this weekend because it's too time consuming. They're holding a dyno shootout, so they're letting 20 people dyno for free.
I'm getting nervous
I tried to get some video last night, but the sound was awful, lol.
I'm getting nervous
I can't believe I washed my car today...It needed it though, badly. My rear bumper, hatch and tails were just covered in fuel and carbon
. I'll have some pics and videos up tomorrow and Sunday from the PTuning event.
good luck carbon.......oh btw i reread the codes i was throwing and the one thats making my car stuter and surge is "crankshaft position sensor system malfunction" so i disconected the fic and cleared the code. after that i didnt have any problems what so ever and the only code i throw now (running stock tune) is system too rich bank 1. so i need to figure out whats wrong with the fic. its either fic or the harness so idk. if anyone has any pointers im all ears.
Originally Posted by Ace83
i have question about aem fic, do you guys have an option to connect the aem wideband to the fic and do datalogging on that? that would an awesome way to street tune
You have to wire in the AEM WB into the FIC harness, and then enable it in the FIC software, so it knows to start capturing data from the AEM WB.
I found the info for a friend a months back.
I don't know where its at, lol. It wasn't easy to find at the time.
Hope that helps ^^
^^ then those who have both should do that! datalogging does wonders and even checks out very lil lean and rich spots on the tune that sometimes you miss by just looking at gauges
i tried to do some tuneing this weekend, it just seems no matter what i change on the fuel map my afrs stay the same. im a little too nervous to mess with the 02 map or the maf map.
maybe you change values too conservatively lol, you can actually be aggressive adding fuel but slowly removing.. on part throttle thats the trickier one because of the closed loop.. i say do everything first at WOT once you got the WOT afrs perfect those will be your underlying fuel map then work your O2 map on part throrttle, I suggest tuning from about 1-2k rpm range at a time then move on the next as you got it right
