CarbonXe is boosted. 287.2/272
im not 100% convinced that the resister did anything but that one cel never came back after it. so maybe it did
I was getting some lean readings befor that whole mess, i just know that i was getting good reading until i started messing with my boost settings on my mbc
the crankshaft position code? yeah that what that resistor is for, you need it.. But messing with the boost controller like turning up the boost? just add fuel on the map you might need it coz you increased your boost.. if you have a laptop datalog
Originally Posted by Ace83
thats on your built motor already and meth injectors? if so I would shoot for 12 afrs.. on stock motor with no meth stay at 11,5, youre in FL that can see 70s weather even on winter lol, those guys on cold weather are safer from detonation so they can go like low 12s on winter. And where is your ignition at from 8-12 psi?
you can go 12 on low rpms 2.5 to 3.5k then make it sweep to 11.5 afr
And get a laptop already and do unlimited street tuning!
I'll just stick with 11.5 ^^
As far as timing. I think i'm at about 15degrees at 8-12psi.
alrigh jon here is what iv done, give me some ideas how to fix some of the lean conditions.
i cleaned my maf
tightend the clampes on my intake pipe (one that clampes the tube to the turbo was pretty lose)
my exhoust is leak free (replaced the doughnut gasket)
cleared all codes (only one i had this time is p0171)
reloaded your newest map
started up just fine this time idled at 1500rpm for about a minute and afr wher rich (as expected).
warmed up and rpms went back to normal (700-750rpm) but afr went to 16 and stayed ther consistently.
on light excel gears 1-3 will lean out after hitting 2500rpms roughly 16afr.
ill have to wait till next weekend to use my cousins laptop again, so if anyone got some suggestions on what to look at and concentrait on im all ears.
i cleaned my maf
vac holds steedy i dont really think thats really gonna do it but i havnt checked to see if the o2 sensor is on tight or any leaks around it
good call ipp ill check it out soon, i just didnt think about the 02's
i only had one oil leak and thats when i installed my oil cooler. the sandwich adapter i used replaces the stock size oil filter with a larger one...............you see wher this is going...lol
5-6psi is ____ing sloooooooooooooooooow lmfao. I don't know how some of you guys can stand it. I don't know if I'm going to last until spring being this slow.
15 degrees might be too conservative espcially at 7-10 psi, you may need to advance that to get more power like jon's numbers.. im 17 at 8 psi right now, i cant wait to get back to town and dyno tune
i didnt really hear it before cause i guess i was running my qtp half open for a while.
