CarbonXe is boosted. 287.2/272
Old Dec 3, 2008 | 01:32 PM
  #1661
CarbonXe's Avatar
I think I've narrowed my boost controllers to the Apex'i AVC-R II and the HKS EVC.
Old Dec 3, 2008 | 01:33 PM
  #1662
brett561tc's Avatar
you wouldnt if you had robot ears.
Old Dec 3, 2008 | 01:36 PM
  #1663
CarbonXe's Avatar
How much do clothes cost in the Matrix?
Old Dec 3, 2008 | 01:46 PM
  #1664
mospeedtc's Avatar
Get a CB radio so you can talk to other car beds
Old Dec 3, 2008 | 02:53 PM
  #1665
brett561tc's Avatar
Old Dec 3, 2008 | 03:00 PM
  #1666
ippskidder's Avatar
1UP Crew
Theres a version II??? lol
Old Dec 3, 2008 | 03:10 PM
  #1667
CarbonXe's Avatar
Yeah, I think it's the same as the I, but it's black instead of silver.
Old Dec 3, 2008 | 03:13 PM
  #1668
brett561tc's Avatar
^how much?
Old Dec 3, 2008 | 03:15 PM
  #1669
CarbonXe's Avatar
High 400s, low 500s.
  #1670
rhythmnsmoke's Avatar
Music City Scions
Originally Posted by brett561tc
^how much?
$495.00ish
Old Dec 3, 2008 | 03:16 PM
  #1671
Music City Scions
Ooo....close post.
  #1672
CarbonXe's Avatar
I want the Blitz, but it's just way too much money. It's like $800.
Old Dec 3, 2008 | 03:18 PM
  #1673
ippskidder's Avatar
1UP Crew
I may be mistaken. But I think it has the same hardware. Its just a special edition because its in black ^^
It does look sexy though.
Old Dec 3, 2008 | 03:20 PM
  #1674
brett561tc's Avatar
my friend is selling his for $400. its got alot of functions. he just has a really good standalone now and doesnt need it anymore.
  #1675
CarbonXe's Avatar
Yeah, I've seen it for as low as $450 and as high as $550. MSRP is $650 lol.
This is my other option.
A little more money.
  #1676
ippskidder's Avatar
1UP Crew
I would love to test out the Blitz.
The dual solenoid feature is enticing.
But I <3 the avcr tweakabilitiy.
I'll have to read up some more on the Blitz. It might be for the next car =D
Old Dec 3, 2008 | 03:22 PM
  #1677
CarbonXe's Avatar
How easy to use is the A'pexi? I basically want to run wastegate boost (assuming 0% Duty Cycle) and 10PSI. I like the sound of scramble boost too, adjust whenever.
Old Dec 3, 2008 | 03:25 PM
  #1678
brett561tc's Avatar
from there website.
SBC i-Color **NOW IN PSI**
This product's purpose is to control the boost of the turbocharger and improve the output of the engine. A state of the art digital controller for an accurate gain in boost pressure, which controls either one (Spec S) or two (Spec R) highly efficient solenoids which achieves a minimum over shoot on peak boost and stable boost pressure.
Features of the product
* Boost control & power meter function.
An added function, the Result graph, which displays the results of power, torque, boost, and A/F overlapping to each other on one screen. It has a function as al logger according to the RPM to compare a maximum of three channels on the horizontal axis that are power, torque, boost and A/F.
* The ultimate boost controller
The known full auto function evolves further in the SBC i-D series. A still more precise control is added to the auto boost setup. In addition to the new full auto function in which the self-learning method can be chosen in three steps, a boost according to the RPM and speed is possible to setup to match on all the stages.
* Full color (65.000 colors)
The graphics that the full color display made it possible are; such as displaying from analog to digital meter, graph comparison display and a possibility to produce a variation of back ground images. If the optional TEMP sensor and PRESS sensor are connected, it is also possible to display water temperature or oil temperature and oil pressure. If the optional A/F Box is connected you will be able to display real time A/F ratio.
Note: There are 2 plugs for optional sensors. One is strictly for Temperature and the other is for EITHER Pressure OR A/F. The unit is NOT able to display both Pressure and A/F.
Optional Sensor: CODE 19210 Temp Sensor Set USD 135.00
CODE 19211 Press Sensor Set USD 135.00
CODE 15063 A/F Box with O2 USD 550.00
Monitoring functions
* Digital display:
A total of 12 data (Boost, Tacho, Speed, Power, Temp (Oil/Water), Fuel Press, Oil Press, Data 1 ~3 (A separate harness is necessary) can be monitored and it can display simultaneously on screen a maximum of six data.
?A/F can be displayed at the AUX port or at the external voltage port Data 1 ~3.
?The sensors are necessary to purchase separately.
* Analog display:
The Boost, Tacho, Speed, Power, Temp (Oil/Water), A/F, Fuel Press and Oil Press are reproduced as an analog meter image at the LCD. It can monitor a maximum of 4 data, including the digital displays at the screen, and the boost set up is at will. Moreover, the background can also be chosen from a white, black, carbon, and blue.
* Multi-angle display function
The display of the LCD can be set as left, right and perpendicular (the LCD at the top) operation angles. By selecting any one of these three angles, the switches also change automatically to the related angle.
* Convenient functions
It has a full load of convenient functions, such as a peak display, independent warning setup by source, maximum of 10 minutes of record/replay function (replay function can convert the unit displayed), back light adjustment, dimmer function, contrast adjustment and language selection.
Optional A/F display function
If the optional A/F amplifier unit is connected, the A/F ratio can be measured and monitored, which can compare with boost or other sources. Thus, the boost setting can be broadened.
Regarding the boost controller
* Sequential valve control (Spec R only):
Two-solenoid valves operate sequentially depending on the valve-open ratio. Mainly, the first valve will do most of the work at low valve-open ratio and at high valve-open ratio; the second valve will come to play.
* Automatic correction of boost pressure (Initial learning):
It will automatically correct to the desired boost pressure that has been configured. A C mark will change color from RED to WHITE when the correction cycle (DUTY value) reaches the desired value. While the C mark is lighted, the SCRAMBLE MODE or the SPEED MAP MODE will not take effect on the used channel. However, the boost control will take effect even if the C mark does not change to WHITE color. This time, to perform the initial learning smoother, the normal, mild and slow function has been added. The Automatic correction of boost pressure is not applicable on manual mode.
Fuel Consumption Function
With the latest model of the SBC i-Color, a fuel consumption display has been added. This function allows you to see how much fuel you are using in real time. There are a few different situations in which the fuel consumption can be calculated. Instant, Average, and Distance fuel consumption can be displayed. We utilize our own original calculation based on the generated horsepower reading.
External voltage input
It is possible to display, record, and replay by inputting an external voltage of 0-16V up to three channels. It is possible to change the voltage scale from -999 ~9999. It is also possible to arbitrary setup the value. Therefore, it can be used to record the throttle voltage, airflow voltage, water temp and replay for reference as a setting tool. The external voltage input harness is sole separately.
Product name: External voltage input harness
Product number: 15053
Manufacturers suggested price: USD 45.00
Function: It can display external voltage source of 0 ~16V by taking it to the boost controller.
Old Dec 3, 2008 | 03:27 PM
  #1679
CarbonXe's Avatar
Old Dec 3, 2008 | 03:28 PM
  #1680
brett561tc's Avatar
for the harness.
