CarbonXe is boosted. 287.2/272
Originally Posted by GReddy_tC
What did you do to it. chanhe the timing..
Originally Posted by Ace83
carbon, question about the ptuning exhaust.. did you remove anything from the car like heat shields and stuff? have some good rattling underneath..
Spipe > 5" of pipe > giant muffler > 20" of pipe > rear section
The only thing I removed was the frame brace that goes directly under the rear seats. It wouldn't fit when I had the muffler backwards and forgot all about it when I spun it around.
hey carbon what slave version are you running on your fic....i just found out i was running the wrong one...im now on z104.hex and i think that fixed my whole stumble issue but not sure just yet.......need to drive around more
So the big muffler side connects to the 2 bolt to vband adapter (5" pipe) then the straight pipe side connects to that 20" pipe?
I tried it that way and the muffler hits the heatshield where the secondary cat is.. I think its that straight bracket that rattles witht the muffler, i had it bent but i guess it still hits
The muffler side should be in the front, once everything is tightened up it will go into the right place. I didn't have any rattles at all after I put the muffler in right, even with my TT downpipe in it doesn't make any noise, the only thing that does is the dumptube.
Guest
Posts: n/a
oh I see, I prolly will bend that heatshield and see if it will fit better..
but this how I had it in order
MrC
no spipe since getting todds for better fit with his dp. seems like the order on that pipe is correct when i pmed MrC, he will post pics soon but ill try yours if it still doesnt work
The order is right, but the muffler is backwards and upside down. The way it is right there, with the muffler farther back, it will hit a bolt that holds the heatshield in place.
Originally Posted by SoFloTC
ya i installed mine upside down thx to that picture.. and ended up scraping my muffler on thousands of speed bumps for 2 weeks lol! o well
We cant let this thread die.. Back to the front page..
