Descendant intake manifold
Old Dec 23, 2010 | 03:13 AM
  #381
creamyxb2's Avatar
Originally Posted by Rob_DESCENDANT
DESCENDANT Intake manifold has been tested & is currently raced on the most powerful 2AZ-FE Scion in the WORLD and it's made here in the USA.
Weapon R is not currently been tested or raced by any professional race team or motor sports facility and is made in China.
i dont think spending 500 to gain 10hp is cost effective. i was hoping on more hp i guess.
Old Dec 23, 2010 | 03:39 AM
  #382
A-snell's Avatar
it's not just about the HP. figure in the styling, craftsmanship, and made in the USA!!!
show me an intake that will give you more than 10hp.
Old Dec 23, 2010 | 08:52 PM
  #383
tokenride86's Avatar
how much does a cold air intake and exhaust cost? ill bet its more than 500
Old Dec 23, 2010 | 09:30 PM
  #384
weezyfbayba's Avatar
does anyone know the size of the throttle body o ring? i got the ones that bolt to the head just can't find the tb o ring
Old Dec 24, 2010 | 08:00 PM
  #385
creamyxb2's Avatar
i m not ******* were its made. i was just hope on the closer side of 20 hp. now i didnt read the whole post but what were the number on a boosted car. i don't care about n/a. now is this hp reads on stock cars. no intakes. cams. tunes. ect. this is bolted on to a stock. then thats not to bad.
Old Dec 24, 2010 | 08:02 PM
  #386
creamyxb2's Avatar
name brand stuff u will spend 500 on just the exhaust. ebay sh-t about 300 for both.
Old Dec 24, 2010 | 08:05 PM
  #387
creamyxb2's Avatar
Install ins't to bad especially since it bolts right up without any modifications, just a little time consuming if your working on your back.
As for DYNO numbers our boosted 2AZFE customers can expect a minimum of 15% increase in WHP at low boost an as much as 25% on high boost applications. The CNC velocity stack runners & extra large aluminum plentum are the perfect combo for any forced induction application.
As for our NA customers they can expect anywhere from 18-25 WHP increase with this addition however we are actually getting ready to run several NA compraisons where we believe customer will be able to squezze even more power out of it with their NA 2AZFE's. I'll keep everyone posted as details become available.
there thats what i was looking for.... im sold on it.
Old Dec 28, 2010 | 08:59 PM
  #388
MrBurrito's Avatar
I want to get one of these after i finish my fuel system and raise the boost.
Old Dec 29, 2010 | 02:25 AM
  #389
A-snell's Avatar
I was hopin that the big guy in red would bring me one.... but alas.... nope. looks like I need to start saving...
Old Dec 29, 2010 | 06:19 PM
  #390
Kanchi's Avatar
Drool...want
Old Dec 29, 2010 | 06:26 PM
  #391
and neither will even produce 5 whp.
Old Dec 29, 2010 | 07:18 PM
  #392
johnnyb305mia's Avatar
on an NA build with a tune im sure u can get 8whp for boosted apps ur prob looking at 16whp those r my guesses for most ppl but more is always better
now if u jus slap it on well idk if that would benifit at all
Sent from my T-Mobile G2 using Tapatalk
Old Jan 3, 2011 | 01:01 AM
  #393
cmcpride's Avatar
Default manifold
yes thats what i was asking longer tubes compared to shorter tubes .whats the difference
I think he was expecting a more "technical" answer...lol.
My understanding is that WR has long runners. The long runner IM from what I have researched is a low-mid range enhancement. While the short runner IM like Descendants is better for the Top End performance.
Old Jan 4, 2011 | 06:52 PM
  #394
Rob_DESCENDANT's Avatar
General rule of thumb would be that the short runner intake manifolds are designed for applications looking to increase high RPM horsepower where as a manifold designed with longer runners is going to increase torque & midrange but probably sacrifices top end power.
This can be confirmed thru www.wilsonmanifolds.com
Old Jan 14, 2011 | 05:21 AM
  #395
cmcpride's Avatar
i searched but unable to find any thing that talks about how the length affects mid or high end gains.
General rule of thumb would be that the short runner intake manifolds are designed for applications looking to increase high RPM horsepower where as a manifold designed with longer runners is going to increase torque & midrange but probably sacrifices top end power. but i found this http://www.wallaceracing.com/runnertorquecalc.php
Old Jan 22, 2011 | 12:27 PM
  #396
JDMSam's Avatar
Yes, we do have comparison numbers (CFM) to compare the OEM piece to our Descendant intake and if I remember correctly our manifold flows 22% more air at static pressure when compared to the OEM plastic manifold. I'll post the comparison once I get back to the office next week.
As for pictures, here is a picture of the CNC Velocity stack runners we use on the Descendant Intake Manifold, I also included a picture of an un-welded piece to show the precision fit.
Bump for the comparison. This intake manifold reuses the stock throttle body, correct? Will it also accept any larger tb's?
Old Jan 23, 2011 | 01:03 AM
  #397
southernsttc's Avatar
Rob-
i will b calling u by march or april depends on when my BP check comes in... hahaha
i would like 2 buy the Bolt-On & Go turbo kit also the Exhaust and IM... so just a reminder and giving u heads up...
-Jorge
Old Jan 23, 2011 | 10:22 PM
  #398
does it matter what way the throttle body mounts? only way it fits on my intake mani is with the sensor up top. it the picture its facing downwards
Old Jan 27, 2011 | 01:01 AM
  #399
boostedrs1's Avatar
Well i didnt read every post in here and im not sure if not only gaining power but also the strenght of there manifold!!... Im sure im not the only one but 1 1/2 years ago i was stock motor running 15psi and just cruising on the highway got on it and heard a nasty rattle noise. I was thinking wow finaly did some damage but got back to the shop and came to find out it was my stock manifold that blew up on the inside the runners separated from the plastic. figured no point going stock again and got descendants mani and well it was a difference for sure!!
THANKS FOR THE QUALITY AND AMAZING PRODUCTS!
Old Jan 27, 2011 | 04:11 PM
  #400
Syldrin's Avatar
i am jealous of that tool box
