DIY: e-Manage Ultimate 2-Step Setup..
Old Sep 24, 2009 | 03:08 PM
  #61
RichTc's Avatar
I got an email back from the Greddy, but they didn't quite understand my question about the indicated external switch for the 'power shifting feature'. So I called them, and spoke to a Tech whom indicated that he would have to talk to the head tech and call me back. I'll let you guys know what he lets me know, once I hear back from them.
Old Sep 24, 2009 | 04:14 PM
  #62
rhythmnsmoke's Avatar
Music City Scions
I was trying to some how correlate the way that the WOTBox hooks up for flat shifting and somehow translate that over to the Ultimate. Again, I haven't had time to test it so not sure if the Ultimate even needs it (to hook to the clutch switch that is). Since the setting is an RPM setting in the Parameters. With the WOTBox, if I'm not mistaken, you don't setup any "Shift point" RPM wise in order for it to work. It works based on sensing the switch engagement from pushing in the clutch itself.
Old Feb 4, 2010 | 03:30 PM
  #63
m6ar2cel6oTC's Avatar
Originally Posted by gingles
still not sure of the cluprit paul, i used the airflow adjustment map and corrected it though....and cory your time is coming man....if you remember correctly my ignition map wasnt selected son....we can try your 8 psi to my 16 soon....see how much boost i need to use to make up for eth hahaha....remeber guys....make sure you have a dip switch for your ignition map selected....if not enjoy some nice knock like i did....luckily i got it soon enough before damage occured.....ive just been to lazy to go out and street tune
i was bored so i was looking through this. whats a dip switch?
Old Feb 4, 2010 | 06:03 PM
  #64
gingles's Avatar
on the front of your emanage are 4 switches....each one controls a different map.
Old Feb 4, 2010 | 10:44 PM
  #65
Default Re: DIY: Emanage Ultimate 2-step setup
O knew that but didn't know what it was called
Old Mar 27, 2011 | 11:15 PM
  #66
myr6goesfast's Avatar
TTT***
Ok, since I PMed a few people about my problem individually and didn't want to help me out I'm reviving this. I'm trying to set my 2step and it keeps bogging out when I try making it work. Does anyone have this set properly that can help me out? I've tried different RPM to start and it's gone as far as chirping at take off then bogs while I'm holding the gas pedal down, then slowllyyyy starts taking off.
Old Mar 27, 2011 | 11:47 PM
  #67
ESEMRFOZZ13's Avatar
Originally Posted by myr6goesfast
TTT***
i do not see your problem in this thread? when is your fuel cut? launching, redline?
Old Mar 28, 2011 | 12:32 AM
  #68
Music City Scions
TTT***
Your RPMs need to be set to no less than 4000rpms. This applies to the WOT Box, and other 2step launching systems from my understanding. Otherwise if set below that then it's going to go flat after a few bounces off the 2step.
Bounce Bounce Bounce....Flat....Bounce Bounce Bounce....Flat... was what I experienced at 3k rpms.
Secondly, you need to adjust the IGN cut box. The IGN cut setting is going to dictate how the car launches. Think of it as Traction control, set to high it will just give you a weak take off. Set to low and it will spin the tires (delivering more power to the wheels). Have to play with it.
Old Mar 28, 2011 | 03:34 AM
  #69
That makes sence... thank you. I'll try messing with it tomorrow and take a pic of my settings.
Right now it's like this:
Start-3800
IGN Cut rpm-6100
shift up-5800
Throttle-80
IGN-0
pulse-0
Old Mar 28, 2011 | 03:49 AM
  #70
good to see your still around rythm, i would have thought he read the posts you put in the 1st page before asking.
Old Mar 28, 2011 | 05:15 AM
  #71
thendawg's Avatar
4500 rpm launch -15deg will launch HARD making almost 10psi on launch on a 6262 hahaah
Old Mar 28, 2011 | 02:05 PM
  #72
Music City Scions
Still alive and kickin...
And it sounds bad **** to don't it...
Old Mar 28, 2011 | 06:57 PM
  #73
I'm not boosted. I've played around with all kinds of settings and it has all bogged down on me. Thank you for your input, even tho it has NOTHING to do with the topic...
Old Mar 28, 2011 | 11:42 PM
  #74
how are my questions off topic myr6goesfast, the answer givin is also in page #1.
Old Feb 15, 2020 | 09:37 PM
  #75
MR_LUV's Avatar
Administrator
Administrator
Thumbs up
Becomes a Sticky
gingles
May 21, 2009 03:34 AM
Mecanica_Pito
78
Sep 15, 2008 04:12 PM
Whocares05050
13
Nov 18, 2007 09:11 PM
moderngti
Dec 29, 2006 04:51 PM
twiztedillusions
12
Jun 16, 2006 08:30 PM
